IanS »
https://forums.nicoclub.com/ians-u23642.html
Mon Sep 22, 2008 8:43 pm
An FIC, or S-AFC will be able to adjust for the different MAFS while adjusting fuel control at the same time.
Sound like you are looking to build the car to be fun, kind of sounds like mine.
I would start by getting the exhaust and intercooler, they will make a huge difference, even on stock boost. Then I would get the boost controller of your choice. Crank the boost to 12 psi, and go have some fun.
I would suggest looking into an oil cooler also, the SR20s like to cook their oil, and a cooler is cheap insurance.
For what you plan to do, I think a ROM tune is definitely the way to go, it will afford you much better driveability day to day, and it will allow you to retain ECU learning capabilities. Once you have gotten your turbo installed, order the MAFS and injectors, and send out the ECU. Install all three at once, and have a blast.
As for turbo manifolds, they really aren't necessary. they crack, and tend to increase under hood temps. I would look into having the stock manifold extrude honed, it will be cheaper, and more reliable in the end.
