skotluvscars wrote:225/50's WILL fit if the specific tire's dementions allow it.Some tires will fit say 6''-7''. Look for the specs on your specific tire.Believe me 225 width makes a big difference in corners-plus they look beefier.-Skot
Can you post up pics of the 225's you have on your stock alloys? I'm curious to see how much they stick out and how the tire's bead looks on the rim.
I run 205/60/15's (Potenza RE950's), and i'll tell you they look chubby as hell. Increasing the tire size beyond OE specifications is going to increase sidewall flex even more, and give inaccurate speedo readings.
Just bite the bullet and buy a nice set of 15x7's (or wider) and run your 225/50's on them instead, it will look nicer, and the extra inches will give more support to the tire's sidewalls.
