First off what engine and series are you working with. From what i can remember from doing my wiring plug one looks like your eccs relay. From the readings you took the relay is working. As for plug 2 i dont know what that goes to, but from the readings you took the relay doesnt appear to be working. I dont have that relay in my r32 rb20, so i dont know if it is used or not, but plug another relay in plug 2 and see if it runs. When you tested the injector harness for voltage did you prode one lead to a body ground and the other lead to one of the wires? The injector has power at all times and the computer using a ground signal to open it up. You might want to get a ecu pinout and check all of your power and grounds that the ecu is supposed to have. If you dont have a pinout you can get a a pdf service manual from
http://skylineking.com/info.html to help you out more. I really need to know what series rb20 you have before i can really help you. Im assume your plug 2 relay is bad and it is a major power feed to the injectors but i dont have the car to give you a definate answer. A lot of info but hope this helps.
