mott6904 »
https://forums.nicoclub.com/mott6904-u55683.html
Sat Jan 19, 2008 11:05 pm
there are no orange relays just blue and green if i recall. Someone said that from the picture you posted that he could tell that there was supposed to be a wire that connect to the orange wires that go the the realys. Ive never seen this seeing how the computer uses the orange wire to turn on the relay but i could be wrong. Id say that if you have both relays plugged in then make sure that when the ignition is in the on postions that the eccs and fule pump relay wires are ground( refer to website i gave you for fsm), and make sure that all of your major sensors and and injectors have power and ground.
