Who the fu*k are you talking to?ryandevilhorns wrote:For drifting I'm assuming, that would be pointless on a steet 240. Stock rear calipers have cable and hydraulic.
Y-O-U.Dattebayo wrote:Who the fu*k are you talking to?ryandevilhorns wrote:For drifting I'm assuming, that would be pointless on a steet 240. Stock rear calipers have cable and hydraulic.
Then why are you answering a question I didn't ask?ryandevilhorns wrote:Y-O-U.
FlatBlackIan wrote:There is really no logic in your thinking.
What would be the purpose of using hydrolics as opposed to cables? The factory systems generally work well, and are relatively maintenance free.
First of all, adding a second calliper to the rear doesn't make sense. Not only will it be difficult to package, but it will also add lots of extra weight, which is bad. And that is unsprung weight, which is worse. Yes, in motorsports it is occasionally done, but that is with ultralight alloy callipers on fully custom knuckles.
Secondly. the whole purpose of a hydrolic side brake (called such because its not there for parking or emergencies as much) is for motorsports. Hydrolic systems are easier to tweak, and stronger, plus you can switch out brake systems, without figuring out what cables work.
The ABS issue? 99% of people who have a need for a hydrolic side brake, had long since dispatched with the the ABS and stability control.
Also, how do you plan to use a factory lever to activate the hydrolic system? Factory levers are meant to pull on a cable, while hydrolic system pushes on a master cylinder. I think you will have a much harder time packaging all that under factory interior, which is often rather tight.
Not to mention the upkeep and maintenance on the system would be much worse than on a cable setup.
It really just does not make sense. If you need a hydrolic side brake, then you likely want to move it anyway. The reason they put racing sidebrakes upright, or in custom locations, is because it is often very difficult to reach a side brake while strapped into a rigid bucket seat.
Yeah, they stretch out over a period of YEARS. Hydraulics require more maintenance than that.ricers1 wrote:well the oem cables stretch over time
You have no idea what you're talking about.ricers1 wrote:an oem caliper is really not all that heavy.
240sx's don't have parking shoes. You're confusing the Z32 brake swap with it.ricers1 wrote:and you would be taking out the parking shoes, and all the working of that system.
"Alloy 2 pot"? You really come off like a silly salesman who only knows about 10% about his product.ricers1 wrote:i only said my goal is too try to get everything under the factory trim, also i would be selling the caliper with the kit, so if one chooses they can get alloy 2 pot caliper or whatever.
Okay, so you actually think someone would install a whole other caliper on the rear in addition to the one that's already there? This is the silliest idea in history.ricers1 wrote:really the only maintainance would be replacing pads from time to time but they would be used as much as regular brakes so they would wear as fast. and ive had experiance with the parking shoes falling apart and getting jammed in the brake rotor and causing more issues
So what did you do then, rich? Or are you not at liberty to discuss it?Koshin wrote:I own two cars with Hydro E-brakes...
neither of which came as a kit. You have to make them work for you application.
I dont know if this helps, but I didnt want Dave having ALL of the fun
I know.Koshin wrote:I didnt touch this one man. My buddy Dave Mitchko (the guy who does the work that I cant do to the race cars) figured this one out. I wouldve just messed something up. I know it works though haha
I would go thru the trouble of getting the info for him, but I dont care enough to know how it works to do so.
Im a jerk
...PS, (so are you Dave)
Like I said, it's an adaption on a line locker, probably...Koshin wrote:nope, I do know that
I dont see it being needed. Im no engineer, but seems excessive
I wish you would let me hydrate your locks.93coupe wrote:I keep my hydro on lock. That ish is expensive.
93coupe wrote:Golden shower, oooh that's dirty
