biggie »
https://forums.nicoclub.com/biggie-u182.html
Sat Jan 13, 2007 11:54 am
For those that don't have map lights, this for wiring the map light rear view mirror. I didn't take pics of every little detail though.
Unbolted and removed the driver's side visor and the center dome light. Unscrewwed the one screw on the A-pillar and removed it.
-Ran the 2 wires needed beside dash to underneath.
-Used a connector and hooked the ground underneath the bolt holding the TCU behind the kick panel.-Solder the power wire to the PURPLE wire(T-style) running to the flip-up switch.-Soldered in an inline fuse holder to the power wire, runing a 10amp fuse.
-Used male and female connectors to wire to mirror (after cutting off connector). The black with BROWN stripe is ground. The SOLID BLACK is power for individual lights. Black with WHITE is for 'dome' use (I did not use this but could be wired to the dome light power source).
-Tucked in wires along A-pillar. Used small zip ties to hold together and a couple zip ties in holes not used by the pillar cover to hold them (the rectangle holes are for the pillar cover to snap into).
-Tucked behind the upper cover, be sure not to be in the way of the visor or dome light screw holes.
Nice and neat.
And complete.
