Basdog539 »
https://forums.nicoclub.com/basdog539-u315114.html
Thu Mar 20, 2025 6:59 pm
I just received some parts today, the new Hitachi iacv, and also a camshaft position sensor and a crankshaft position sensor. One was leaking oil the other the plastic connector part broke (combination of old plastic and working on the vehicle outside in cold temperatures). I also got new gasket kit for intake manifolds, vvt solenoid (yet another leaking point), throttle body. I tried my best to use an inspection mirror to check the water control valve tube for the leak where it meets the head. It's hard to tell. It looks like it might weep a very small amount but not enough that it would account for the dripping coolant off the bell housing. I will try the dye but I recently repaired the a/c and found the leak using dye so currently a lot of parts under the hood glow under uv light. I really wish they made different color dyes. If it is the gasket on the cools cross pipe and the vehicle being as old as it is I've wondered if I could simply cut a hole in the firewall in order to make the repair from in the cabin and then just weld a piece of sheet metal back over the hole. I know that would reduce the rigidity of the firewall but really not looking forward to dropping Trans. If I do I will also be replacing the upper oil pan gasket and rear main as I'm pretty sure I have an oil leak from one or both of those as well. Luckily we have other vehicles and I enjoy wrenching. I'll let you guys know how it runs with the new iacv.
One other question, if tge bad iacv took out the driver on the ecm, will a damaged ecm destroy a new iacv? As always thanks for all the help.
