questions
Masterdebater
Car: 1989 nissan 240sx coupe
alright i need to know what products i can use to raise boost safely and cheapest and what it can cost. or if there is an aftermarket internal wastegate for the t28 that is adjustableand ive asked before but never got the answer...what is iirc mean?and possibly a little info on how to read what the safc is telling me and how i can tune it if i learn wehat im doing lol
wewders
Car: 93 SE RS13, 90 RS13
Water injection is a cheap way to safely raise boost. Joseph Obernberger sells water injection kits on his website http://water.lovehorsepower.com/
$360 for a stage I (single port injection)$410 for a stage II (dual port injection)
Or you can source parts and make your own kit for a little less.
But if you're looking for a shortcut to higher boost, and you haven't already read Dee's sticky zerothread/230677 then you definitely should. That's wisdom right there.
Dunno about the wastegate...doesn't seem unlikely.
iirc stands for If I Recall Correctly.
Hope I was helpful.
Zero260
Car: 91 240sx coupe
cheapest way to raise boost is w/ a manual boost controller, but I'd read Dee's post 1st. cause cheapest useulally isn't the best.
Nunook
They do have an adjustable wastegate for the t28. HKS makes one, and I think some other company, cant remember the name.
Water injection is sick, I still wanna get my windshield washer bottle back in the car so I can mist my intercooler.
Masterdebater
yea ive read the faq already loli have 440 injectors and afc tuned with t28 turboits tuned for about 12 psi right now and the t28 is still sadly at 6 psi and is nothing..
float_6969
Yea, the T28 @ 6psi on the CA isn't much fun. I built a manual boost controller that worked pretty darn well for about $25. The only reason I got rid of it was because it couldn't be adjusted from in the cabin.
