I think the problem is the Sentra 2.0 (non-S) doesn't even have power door locks. Even if it did, I am sure it would not come with a receiver for the remote/transmitter - just the wiring up to that point at most. So I can't see how even an aftermarket alarm would come with the necessary parts to convert to power door locks.A 2.0 owner may have to live without remote locking or spend a lot of money. At least Nissan didn't delete other important features like side airbags, aux input, etc.TECHLINE08 wrote:if u have power door locks its a good chance all you need to do is program a remote.
It seems like it has power locks - I have the lock buton inside and it is workingSupercourse wrote:I think the problem is the Sentra 2.0 (non-S) doesn't even have power door locks.
I checked this procedure and it works. I also got a keyfob from ebay (with instructions), but pushing a button on the keyfob doesn't flash the lights. I also tried the procedure thom the Sentra manual, but it is not working.So either the keyfob is bad, or no wireless key on my Sentra.I may have to go to a dealer for this.merlinpr wrote:"Close and lock all doors with the driver's side power lock/unlock switch. Insert and remove the key from the key cylinder six times within 10 seconds. Go at an even pace. Don't go too fast or too slow. If you did it successfully and the system is present and functioning then the hazard lights will flash on the dashboard."
That would be very helpful. We should make sure that the right instructions are available here for future reference.merlinpr wrote:.... will try to program it on my 2008 and will post results and details of what I have to do to get it working.
I just got my remote and followed the instructions they included but that didn't work. Here's the procedure I got with my remote in case it works for someone else who might be having issues with this:Supercourse wrote:
For example, some instructions tell you to press the car's central locking button immediately before pressing the LOCK button on the remote being programmed. May or may not be a redundant step. Similarly, some instructions say to press ANY button on the remote to program it, not necessarily the LOCK button. I can see that could be true. Can't remember exactly what worked when I did it successfully, so it needs someone making a careful and conscious effort to document it.
Yeah, I figured I'd give him a chance to make it right. We'll see what happens when I get the replacement from them. Hopefully it works even though I would have liked to be able to open the trunk with the remote. Beats spending over $100 in the alarm I was about to buy when all I really want is to have keyless entry.Supercourse wrote:I am not sure that is correct. The Canadian SL model has the lever/switch that has to be pulled up to release the trunk, and uses the 4-button remote. I think the cable operation is standard, whether or not the vehicle comes with remote locking. In general, all Nissan and Infiniti sedans use a 4-button remote. The 3-button remote is used by models that do not have a trunk.However, the ebay remote vendor may know something that I don't.
Confirmed! I got the new remote without the trunk release button and it worked. The part number for the remote I got is: 28268EA. This is the one with only 3 buttons (lock, unlock, and panic).Supercourse wrote:I am not sure that is correct. The Canadian SL model has the lever/switch that has to be pulled up to release the trunk, and uses the 4-button remote. I think the cable operation is standard, whether or not the vehicle comes with remote locking. In general, all Nissan and Infiniti sedans use a 4-button remote. The 3-button remote is used by models that do not have a trunk.However, the ebay remote vendor may know something that I don't.
It seems like it's the same remote I have on my Versa.Would you mind teling me the other numbers from the key fob (FCC ID and IC)?Also, if you got if off ebay, can you post the link?merlinpr wrote: The part number for the remote I got is: 28268EA. This is the one with only 3 buttons (lock, unlock, and panic).
Thanks
The one I originally purchased (and didn't work) was not a KBRASTU15. The one I was sent originally was a CWTWB1U429.Supercourse wrote:In addition to the Versa, the 28268A remote is also used on Frontiers, Titans and the new Pathfinders.In summary:hienesey has the KBRASTU15 working with a 2008 Sentra (base model)Onyxblue found a KBRASU15 would not work with a 2008 Sentra (base model)merlinpr found a KBRASTU15 would not work with a 2008 Sentra (base model)Canadian Sentras come with the KBRASTU15 as the I-key is not offered (unless this has changed for 2009?)
