Raz007 wrote:Ok, I hear ya. But say I used them, and used the bearings that came with them? Would they free up some after awhile, be dangerous, or just suck a**?
And thanks for being patient with me. Suspension is not my strong point.
Yeah, they might free up, but I'm not so sure.
You might also get some bearings that are tighter than others, their quality control isn't all that great.
But, if you're only going to be on lowering springs, stock arms are completely fine.
On my lowering spring setup, my toe and camber in the rear were all within spec.
My front camber was starting to get pretty extreme due to the dieing lower arm bushings.
I'd say get some new front lower control arm bushings, and get an alignment after the lowering springs, you should be able to get everything to spec and not worry about buying suspension arms.
