RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Wed Feb 09, 2011 6:38 pm
Godspeed is china based quality. They will wear out faster then namebrand parts. Their rod ends and bearings are on the low end. You will replace them.
Really what you want is SPC or SPL. Totally different companies. SPC makes more race/precision oriented stuff. They use spherical bearings and rod ends to make everything more adjustable and precise. They will require eventual replacement, but should last a good long time on a street car if taken care of.
SPC makes adjustable camber arms, toe arms and traction arms with bushings to reduce NVH (aka noise vibration and harshness) Great for a daily driven street car, and tire wear. I recommended a set to my friend and they work perfectly and are easy to adjust.
If all your getting are drop springs and struts, or just going for a mild lowering, you'll probably only need RUCA's. I wouldn't buy front camber plates, that's money that should go for coilovers that include them already.
Honestly, your going way too far into the suspension linkages, and not enough on the actual dampeners and springs. Your way better off buying quality coilovers that handle and ride better, and just some ruca's then doing every adjustable link with drop springs and struts.
Get on Nissanroadracing.com if you want to really see what parts are good and will last a decent amount of time, WHILE performing GOOD.
Whats your actual goal? Decent stance and low tire wear?
~Alex
