pdqwrx wrote:So, some more searching shows that I don't have to remove the plenum.... A mechanic friend of mine looked it up in a Mitchel Manuel and it called for plenum removal and a ton of hours to do it.......Hmmm.
Which side are U doing? If left/drivers side then replace:2= Rear Cam plugs1=EGR Valve Gasket1= ThrottleBody Gasket (makes job easier when TB is removed)
Also may want to repalace 5-7mm Vacuum hoses on ERG Silenoid an Egr BPT and the ones on the hoses that are on the TB and always check and replace spark plugs if needed and re-gap plugs after removal. Also seal spark plug holes while working so U DO NOT DROP a screw into the cylinder. Clean all connectors and use DI-Electric when replacing connectors.
