CoupedUp »
https://forums.nicoclub.com/coupedup-u58258.html
Sun Sep 09, 2007 9:01 pm
I'm fuel fouling them because they're too cold. I am not getting a good/sufficient combustion from 4500-7000 on the 8 heat range. They're meant for a higher flow because the pressure of the volume thats compressed on the compression stroke generates more heat. Since I have a stock turbo and heat range 8s it isnt't working out too well. Now it could be that they are fouled to begin with and swapping in some other plugs(heat range 6) helped tremendously but i'm fairly sure my assumption on this problem is correct.
