Question for those who do their own oil change
exvin
Car: 2000 Nissan Pathfinder
Whats up all.
My parking lot just got better lighting and more space and now I am thinking of doing my own oil changes on the pathy.
My question is, do any of you who do your own oil change use a engine flush first before doing your oil change or do you change the oil straight (without flush)?
Thanks
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
I just drain and refill my oil and put a new filter on, no flush. I'm not even sure what kind of flush a DIY mechanic could do -- drain, refill with 0W40, idle engine for a half hour, drain, and refill with 5W30?
If you've been doing oil changes on the proper intervals, then you shouldn't need one. Certainly not every oil change. On an older engine, it can actually loosen up stuff that shouldn't be loosened up, causing problems.
KyooX4
Car: 2001 Infiniti QX4 4wd
I just drain the old oil, pour the new in, and change the oil filter.
NutsPathfinder
Car: 2004 Nissan Pathfinder SE
KyooX4 wrote:I just drain the old oil, pour the new in, and change the oil filter.
X2
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
x3.
Although when Nissan offers an $18 oil change I let them do it and bring a jug of synthetic.
Pwnin O'Brien
+1, a flushing oil isn't necessary if you've been using a quality oil. If you're really concerned then you can try some Seafoam in the engine to clean it out.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Oil out, oil in. No flush! If your oil is changed on a regular, recommended basis, a flush will NEVER be necessary.
exvin
Great, thanks guys
I am using mobil 1 on regular intervals and it the pathy doesnt burn alot of oil, at least from what I am noticing
Now my next concern is should I buy 4 individual quarts or a large container of oil :)
speedeast
The larger container might save you some money. It should have a capacity window on the side so you don't overfill.
Just remember that the 3.3L oil capacity is 3.875 (3 7/8) US qt 5w-30.
Mobil 1 is good stuff, only oil I use anymore.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
No flush.
Drain oil, replace drain plug, remove old filter, install new filter, fill.
Be sure to oil the gasket on the new filter so that it spins down without deforming the gasket. Easiest way is to just touch it to the gasket on the old filter.
Hand tighten the new filter (no wrench) about 2/3 to 3/4 turn past initial contact at the gasket.
Make sure the old gasket came off with the old filter. Every once on a while the gasket will stay behind.
Do some homework on the web about filter brands. There are some comparison sites. Wix does well, but can be hard to find.
speedeast
Dude, all you have to do is dip your finger in the new oil and run it around the seal on the new filter. Bada bing, bada boom! Tighten the filter until there is no wobble in it anymore, then 1/4 turn. THAT IS ALL!
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
What Id love to know is how to stop all the oil overflow when removing the old oil filter from flowing everywhere. It sucks,
Whats a quickl a dirty way around it other than 15 shop rags and quick hands lol
amaff
Car: 2003 Nissan Pathfinder SE
CanuckQx4 wrote:What Id love to know is how to stop all the oil overflow when removing the old oil filter from flowing everywhere. It sucks,
Um... put the drain pan under the oil filter??? Loosen the filter, let it drain. On mine I don't get any oil anywhere but a little on that little diagonal bar. Just take your time with it. If you just spin it off at once I imagine it'll make a mess, but I've never gotten more than a couple drops splash out of the drip pan...
CanuckQx4
Well on my qx4 there is a 4" wide cross brace or something right therer under the filter and the oil gushes all over that...
Id love to stop that...
I almost wanna get a filter relocation kit...
Do they make them for our cars???
fueler
Car: 2 Nissan's
2 BMW's
i believe theres not enough room for an oil filter relo kit.... pezzy can you confirm this??
CanuckQx4
Do we possibly have an M20 X 1.5" thread??
Maybe this one would work perfect...
http://cgi.ebay.com/ebaymotors/BLOX-OIL ... ccessories
fueler
Car: 2 Nissan's
2 BMW's
SixGuns
Car: '04 Nissan Pathfinder SE 4x4
Flushing is potentially harmful to the internal seals in the engine. Basically a flush is a pressurized detergent that cleans the gunk out. But it's not so good for your motor. Take care of your stuff and that wont be necessary. I use Penzoil Platnum..and the trick to getting no oil everywhere? It's called a ZipLock sandwich bag. Loosen the filter first, then place the bag over the whole thing and spin off. All the oil drains into the bag and not on your arms and face. I only figured that out 'cause my wife's Tacoma has a stupid little catch that the filter sits in that holds JUST enough to not overflow. But then the drain for it is capped with a rubber nipple and you can either let the oil drain all over the front suspension and coolant hoses or use up 1/2 a roll of paper towels. But only 1 ziplock baggie and you're set. The only reason I'd consider an oil filter relocation kit is so I don't have to drop my 40 lbs skid plate every time I do an oil change. ...Cuz it sucks. Thanks, Adam.
WPGQX4
Car: 1998 Qx4
Amsoil makes a relocation kit for our pathys and Q's.
https://www.amsoil.com/storefront/bf.aspx
PM me if you want more info.
Densetsu
Chuck Tribolet wrote:Do some homework on the web about filter brands. There are some comparison sites. Wix does well, but can be hard to find.
One of the most informative sites out there: http://minimopar.knizefamily.net/oilfilters/index.html
I'd agree, Wix is king. In Canada, you can just stroll into a NAPA and get their in-house filter; silver or gold, they're both made by Wix. Most other major retailers here (at least in Western Canada) only carry Fram and Quaker State, both of which are lower grade filters (though admittedly, 99% of the time they'll do just fine).
funnyman82
Car: 2002 Infiniti QX4
do you guys raise your vehicle to do the oil change or do u leave it on the ground? is the OEM filter no good?
speedeast
WPGQX4 wrote:Amsoil makes a relocation kit for our pathys and Q's.
It has to be the BMK23, BMK25, BMK26, or the BMK27 because it must also include the full-flow filter in order to relocate it. Just wanted to throw that out there.
speedeast
funnyman82 wrote:do you guys raise your vehicle to do the oil change or do u leave it on the ground? is the OEM filter no good?
I HAVE to raise mine, but I'm sure the Pathies and Qs can stay on the ground. The OEM filter is just fine, it's designed to be good enough for that car. They wouldn't use a filter that could possibly lead to Warranty work...
BTW, oil filter relocation kit that doesn't have a bypass filter:
Transdapt 1158
http://www.jegs.com/i/Trans%20Dapt/969/ ... /-1?CT=999
KyooX4
You don't have to jack the front end up. But if you don't, you'll probably want a creeper to make it a little easier moving around. You don't need either though.
Densetsu
I'm a big guy -- 6'3", 265lbs, size 40 waist -- and I can change my oil without raising the Pathy.
Admittedly, it's more comfortable to do an oil change with ramps or jackstands -- the biggest pain is swapping the "skid guard" on and off. But raising the Pathy/QX4 isn't required, unless you've got a bigger gut that me.
CanuckQx4
I must not have this skid plate you guys all have. My oil pan and filter is open to your hands
I dont jack my car up, Just a piece of carpet on the riveway and drain n fill the biatch
AJRK
Car: 2001 QX4 4x4, 2003 Jaguar XJR, 2014 Cadillac ATS 2.0T 6MT
Do you guys use a power drill to remove skid plates or just do them manually?
KyooX4
I use an air ratchet. Just faster.
exvin
Yea the skid plates/guards I think I am going to have to do by hand as I dont have a cordless drill
Also not going to jack it up, I can slide rite under, trust me I tried :)
I dont think Canada sells WiX filters though, I have been checking around locally and my local Canadian Tire and Walmart dont seem to carry it. I may have to check a performance shop
I may change out my air filter while I am at it. I have one of those paper filters, may switch to a K&N, unless you guys have any suggestions on that also
NutsPathfinder
I use K&N oil filter and as soon as I get around to it I am gonna get the K&N air filter as well. If I rember correctly the plastic skidplate should be held on with regular philp screws. A regular hand held screwdriver should be fine. Mine got torn off somewhere along the line so I put on the steel one from 4x4parts, its bolted up so it is easier to take of with a cordless.
