Question for those who do their own oil change
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
^Isn't the plastic thing just a splash shield?
Pwnin O'Brien
speedeast wrote:^Isn't the plastic thing just a splash shield?
Yeah, but it has a thousand screws (or so it seems when you're under there).
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
exvin wrote:I dont think Canada sells WiX filters though, I have been checking around locally and my local Canadian Tire and Walmart dont seem to carry it.
Densetsu wrote:In Canada, you can just stroll into a NAPA and get their in-house filter; silver or gold, they're both made by Wix.
WPGQX4
Car: 1998 Qx4
If it wasn't against the rules, I could supply the best filters out there. Pwnin is there some thing I could do to be the Amsoil guy for our section? I'd even sell them at my cost plus shipping.
exvin
Car: 2000 Nissan Pathfinder
I know I saw that but my closest NAPA is 9 kms away...I think I will just use a K7N oil filter :)
speedeast
K&N Filters are great, so you don't have to worry about quality there.
Umm... is 9kms supposed to be far?
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
9km lol, i drove 30 to go for lunch today...
Napa stocks them... but there pricey
exvin
CanuckQx4 wrote:9km lol, i drove 30 to go for lunch today...
Well I can drive 1.5 for a K&N or 9 for the WIX...:)
I can also grab a hotdog at the place that is 1.5kms away hehe
30 Km for lunch.wow.
I work in downtown Toronto itself, right opposite where the G20/G8 is happening..theres like fences all around my office and I need special access to it too...so I usually walk a couple of minutes for food
CanuckQx4
Ya I live in mississauga and drive to toronto atleast 3 times a week for lunch, that was my 30km
exvin
Well oil has been changed
pretty simple..hardest part was locating and removing the oil filter otherwise all went well
Thanks for the advice guys!!
dna9656
Car: 2019 Nissan Rogue SV
I changed the oil and filter on my 2019 Rogue. I poured the 4 & 7/8 (28 oz.) in the engine, I check the oil level after giving the oil time to drain into the pan and when I pull to dip stick the oil on the stick is right on the tip if the stick. The 'H' on the stick is over an inch away, is this normal? The Haynes says it should be up by the 'H'..... The Haynes also says it holds 4 & 7/8 quarts I put in another 2 quarts before it read on the 'H'!!! What's up?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The 4-7/8 is correct for a QR25. If it's reading low after putting in the right amount, running it, and giving it a few minutes, it generally means the drains in the head are blocked and oil from the top end isn't making it back to the pan. Is the motor sludged?
