MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Fri Jan 16, 2004 7:20 am
I have a "small" T3, I guess you could say.
T3 super 60 B, .48 a/r turbine, .60 compressor, 51 trim wheel. I don't see why there's such a vehement propensity toward getting anything but a t3 in the KA-T world.
Correct, mine did drop off from like 9 psi to 6 psi past 5k RPM. HOWEVER, that was from a too restrictive exhaust, which I have since refabricated--I'll have it on/test it out in about a week.
What I will tell you is that with just a downpipe, my T3 boosts a full 10 psi all the way to 6k rpm. So assuming your downpipe/exhaust is free flowing enough, IMO, a T3 my size is perfect. I hate lag--and mine has almost none of it. Throttle response is instantaneous--really really nice. My brother, who has A4 1.8T with a K03 running 15 psi of boost was really impressed with how insanely responsive my engine was with that turbo--you depress the throttle even a small bit, the turbo's spooled, and its making power--down low, and up top.
I make full boost pretty low--and like I said, there's very little lag. I'm very happy with the size of my turbo--and I'll see next week whether or not my newly fabricated exhaust is big enough to prevent boost drop-off.
Yes, 1st and second gear are kinda useless in my car right now, even with sticky 225 dunlops in the rear and an LSD. If you step on it in first, it will spin all the way to redline, if you shift to second, it will spin quite a bit but then finally hook up. If you step on it in second, at about 4500 or 5000 rpm it'll lose traction and start spinning to redline. That's my main problem--traction, or lackthereof. My clutch was in pretty good condition (although it was the original one and had 94k miles on it) before I turbocharged it, but it didnt take long before it'd slip in 1st/second/third--and then finally in 4th. The clutch felt perfectly fine in every gear--except when you started getting up there in the rev range, and it just slipped like nothing. I suggest an ACT street clutch; I'm real happy with mine.
I'm definitely relocating that 35 pound battery to the trunk, and I guess I'll start running a full tank of gas instead of 1/2 for weight savings.
Anyway, hope that helped.
