gbaz77 »
https://forums.nicoclub.com/gbaz77-u38907.html
Fri Apr 06, 2007 3:20 pm
hey uvamosk,
correct, if you have an r32 x-member, you do not need mounts, although it requires some more effort on your part (changing x-members, are simple in # of bolts and whatnot, but not an easy task).
rb20det can change alot of parts with 300zxnon turbo. there is a list in the stickies but some simple things are oil filter, O2 sensor, clutch, even valve-train parts (lifters, shims, valves).
you wont need much from japan except for maybe an original rb20 MAF (however you can use 300zx MAF as well with an SAFC or other computer), maybe a water pump but even that i think not. the myth that parts are hard to get for rb20 has seem to evaded me. i havent had problems, especially for parts that need maintenance.
one thing about sr20 guys, and i have nothing against an sr20, i have friends with them in 240s and they are fast, but the reason rb20 guys are more helpful is that they spend more time on their cars for the install (resulting in more learning and discovery and troubleshooting), and appreciate them more. an sr20 is basically and plug and chug engine. you feel good when you put an engine into a car when it doesnt necessarily belong there.
front view of front mount
view of engine, everything fits fine, no hood clearance issues. and the IC pipe has had no issues going across the variable cam sensor/cam cover.
i ordered a koyo for my engine, but that was because my original radiator was rusted out. ive heard with good electric fans, original KA radiators have been fine. with my KOYO and huge single 12" or 14" (cant remember which) electric fan ive had no problems. in fact, when its cold out, it takes forever to get heat in the car because the coolant stays cool longer.
i agree with the 2.0 liters being split over 6 cylinders. more cylinders per liter equals less work per cylinder. for an easy equation 240hp/6 equals 40 hp per cylinder, 240/4 equals 60hp per cylinder. there is more stress on each cylinder with less cylinders.
one last thing.....the engine out of a bmw 5 series vs the engine out of a 3series bmw is going to cost more in R&D and production, why is it so hard to compare that with the RB, SR engines. Skylines are nissans flagship, the silvia simply is not. more time, energy and money goes into flagship cars anyday than a lower cost car.
gamay
btw - there are so many cheap intercoolers out there. you dont need to spend that much on one there are IC with piping on ebay for $200 or you can get a separate intercooler and separate piping for about the same.
Modified by gbaz77 at 6:58 PM 4/6/2007
