Application: 1990 Q45 w/ level ten transmission
To make a long story short, I was doing a simple drain and fill of my transmission today and over filled it greatly. Don't worry, I didn't drive or even start the car when I did this, it just started flowing out.
Q1: My overfilling it, but not ever starting or driving it could this have damaged anything? I just noticed it start to pour out of somewhere and I immediately drained it.
Q2: The "Home Brew" flush was mentioned by Q45tech and later used by elwesso [
zerothread?id=76109 &
zerothread?id=137129]
What doesn't seem to be clear in either thread is exactly how much fluid is supposed to be used on the last fill (empty transmission on last fill without draining again). The reason why it's not clear to me is because the FSM says transmission fluid capacity is 10-3/4 quarts. Yet it seems that when doing a simple at home drain and fill, you only fill 3-4 quarts. Am I right? Why is it that FSM says 10-3/4 quarts?
If possible, please explain in total dumba$$ lingo
