PyR0NiAk wrote:Built bottom end, bigger turbo, and bigger injectors, but no cams or Z32 MAF??? Weird.. (You're going to definitely want the MAF) It really depends on how well they do with your tune on whether or not you'll need it... Most rom tunes are a little overly rich. I suggest you get a wideband O2 sensor, install everything, and see how it runs.. If it looks like it needs some minor adjustments, get the SAFC.
Yes the 300xz maf is definetly on my list.But for the cam,previously I had a 2001 grand prix turbo(not the supercharger) with around 480 ponies at the crank with the stock cam and it was ok.
Would you recomend a cam for... lets say 330 whp?
If yes which one?
