DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Mar 25, 2005 10:13 pm
I don't know much about forced induction, but 0 boost is normally aspirated. Not sure how you can control a turbo to do essentially nothing, but boost is just a measure of air over what you get without it. No reason you couldn't get 0 boost with a turbo, or 3 psi, but they would be hard to market. You have a MAF that measures the quantity of air, regardless of how it is sucked or pushed into the engine. Good fuel management is controlling the injectors' pressure and opening time to supply the right amount of fuel, with input from the MAF and from the O2s, as well as other things (temp, TPS, etc).
