do you by chance have a dyno sheet? ive been thinking about going to the GT30r but am worried im gonna loose some midrange that i so badly need to keep.T4 RB25det wrote:i think there might be one already, but im not sure
ill start i guess
rb25 s1412.91@10517 inch street tires18psigt30r398rwhppump gasmilan dragway milan michigan
NICE shows the rb26 dominates, put some suspension on and it will feel fasterRamius83 wrote:1995 240sx SERB26DETT, stock, no power mods, running 14ish psiSlicksLSDStock suspension
Times:
R/T..................0.27760'..................1.752330.................5.0271/8..................7.679MPH.................93.521000...............9.9561/4..................11.863MPH.................120.64
injectors???T4 RB25det wrote:i think there might be one already, but im not sure
ill start i guess
250sxGTST wrote:S13 Rb25det 272whp @10psi FMIC SAFC Z32 MAF 3" exhaust Drag Radials VLSD Pump gas stock turbo and stock injectors 12.55et. @ MapleGrove, PA I forget the MPH but it was just under 110 1.8, 60' time
do you have a dyno sheet? cause i made 256 whp @ 10psi250sxGTST wrote:S13 Rb25det 272whp @10psi FMIC SAFC Z32 MAF 3" exhaust Drag Radials VLSD Pump gas stock turbo and stock injectors 12.55et. @ MapleGrove, PA I forget the MPH but it was just under 110 1.8, 60' time
at the time i was running 550 top feed injectors.also done on stock intake and exhaust manifolds.300Plus wrote:
injectors???
I thought it was the Mustang dyno's that underrated them?250sxGTST wrote:I dynoed the car about 9 months ago at Performance specialties in Pottstown, PA. I live in Bechtelsville, PA. If i can find the dyno sheet i'll try to list it. It was a Dynojet. Maybe you had a different dyno. I actually figured there was closer to 300hp available at 10psi as I left the car a little rich becuase this is my daily driver and I want it to stay together.
i'd say that's basically what this thread is...DriftingisLame wrote:Anyone else think it would be a good idea to start a thread like this dedicated to dyno graphs/mod lists?
