12volt is basically a overpriced repackaged fortin kit.
I think there were a couple of taps, but I don't remember having to cut any wires (it's been 3-4 years). Most of it had harness adapters where you plug the OEM adapter into Fortin and then the other end into the main Fortin harness IIRC.
Thank you. I think I will go with the Fortin.Yoda's Master wrote: ↑Wed Jan 11, 2023 6:07 pm12volt is basically a overpriced repackaged fortin kit.
that ebay seller is also just selling you a repackaged fortin set![]()
buy it on amazon for cheaper
Fortin w/T-harness:
https://www.amazon.com/gp/product/B00IEFZ7JM/
Warning: Do not buy the unit and T-harness separately. The standalone T-harness is not the same as the harness from the kit.
Flasher tool (Required):
https://www.amazon.com/gp/product/B0016732QA
Remote (Optional): Pick your own if you want something with longer range, but here's the one I have and it's also the same on the 12volt site.
https://www.amazon.com/gp/product/B01J086F7Y (This is a kit)
You might need to buy this to connect the antenna if you buy a different remote. it's included in the kit above.
https://www.amazon.com/gp/product/B0745THMGD
https://fortin.ca/en/products/
Install guide:
how-to-install-fortin-remote-start-2012 ... 13141.html
you need to splice something no mater which one you buy.
Ok. ThanksIlya wrote: ↑Wed Jan 11, 2023 7:08 pmI think there were a couple of taps, but I don't remember having to cut any wires (it's been 3-4 years). Most of it had harness adapters where you plug the OEM adapter into Fortin and then the other end into the main Fortin harness IIRC.
EDIT: Forgot that we had a HowTo here for it: how-to-install-fortin-remote-start-2012 ... 13141.html
They always require a hood latch switch, but on most models which already have one, all that's needed is reconfiguring the "fob type" in the BCM so it knows to look for an RES button, then registering the new fobs. The RES is almost always a configuration option and not "hard coding" in the control units.Qruising wrote: ↑Sun May 21, 2023 6:12 amHas anyone talked with an Infiniti technician to see if our BCM has the control logic to add the remote start by simply adding the key fob that includes the start button? Below is a location (attempted to make link) to the 2015 Altima key fob reprogramming to add remote start. Note the Altima also required a new hood latch to add the "open" sensor but the Q70 already has that built in.
