Compare the exterior dimensions of the VH45DE to the exterior dimensions of the 350 once. Even though the 350 displaces 76 more Cubic Inches, it is actually smaller than the VH45DE. You made the common mistake of only refering to the cylinder displacement when computing the torque per Cubic Inch.Q45tech wrote:The 1990 Q engine produces more torque per cubic inch [with proper fuel/ignition JWT ecu] than the 2005 Corvette engine much much more than the Chrysler 300c so called Hemi...........274 ci is a small V8.
Didn't you say in another forum that the VH45DE doesn't have enough valve duration at Higher RPMs? There isn't enough time for the air to fill the cylinder.Q45tech wrote:The interferrence of the valve and piston [already have flycuts in piston] means no more lift can be used without new pistons. And 0.490 with a 1.5" diameter valve is already ultra high lift and is perfection for valve curtain area vs valve seat 5 angle cuts.
Cams won't help much because the runners and plenum is tuned to 4,000, 4600, 5600, and 6,000 rpm. Figure out a way to shorten the runners by 2-3" and increase their opening diameter [area] by 8-10% [and maintain the taper ratio] and you might retune the engine to a 6800 rpm HP peak and yield aroud 350-360 HP unfortunately you would lose so much torque at 55 mph cruise that you would have to bump the diff gear up by 25%..........to let the heavy Q cruise with AC on.
Like I said before, I'm just thinking out loud. I just ask these questions to get information. Who knows, when I get a job, I might actually do some of the things that I'm asking about. And then, your information will be very valuable when I try to save more money:).Q45tech wrote:You sure are a long way from saving a few bucks with garden hose plenums to spending $10,000 modifying an engine.
Wow Q45Tech made a funny.Q45tech wrote:Important to take your medicine everyday as Lithium can do that to you. " NO HIGHS, NO LOWS", skip a pill and cams come to mind - seen it often on the boards.
I really shouldn't ask: After hoping that wasn't a complete thought, I need to find out what the voices say is the proper way to compute torque?PoorManQ45 wrote:
This is PMQ.squeefoo wrote:I really shouldn't ask: After hoping that wasn't a complete thought, I need to find out what the voices say is the proper way to compute torque?
Isn't the listed duration the maximum time/degrees that the valve will be open?Q45tech wrote:A cams duration is correct at only one narrow range of rpm [why we have modern designs with VVT or VTEC or iVVT] to try to fake a duration change.
Um... Keeping the Intake valves open while the piston is traveling up the cylinder would seem kind of dumb. Wouldn't that force air out of the open valve?Q45tech wrote:VVT in Q just shifts the FULL closing time of the intake valve 20 degrees later [instead of 48 degrees after the piston starts moving up it occur at 68 degrees after the piston starts moving up from the bottom.
Does that mean that there is 8 degrees of overlap between the intake and exhaust? Wouldn't that cause exhaust gases to re-enter the cylinder? If so, is that to better fill the cylinder?Q45tech wrote:
The exhaust cam closes fully at 8 degrees after the piston is at the top on the exhaust stroke but REALLY stops flowing when the piston is at the top.......nothing more to squeeze out except what's in the head space.......1/10th of the entire volume.
What good would it do to force exhaust gases out of the intake valves?Q45tech wrote:At under 4600 rpm the intake being open 20 degrees before TDC helps wash [flush] some of this 10% residual burned gases OUT [28 degrees of overlap]. This works best at 4,000 rpm.This washing out action is traded for more air filling from the intake above 4600 rpm when the intake opens later [VVT moves the intake cam 20 degrees later.
For a given lobe there is only 1 duration of open interval, no max, no min. VTEC has 2 lobes per cylinder/camshaft to give an entirely different profile, whereas VVT uses the same profile but shifts the angle of it relative to the piston location.PoorManQ45 wrote:Isn't the listed duration the maximum time/degrees that the valve will be open?
I get most of stuff at Autozone, Advanced Discount Autoparts, or Napa(=$$$).texasoil wrote:I like your attitude about finding low cost parts--where can I get some. I want to look at them and judge quality myself.
There is no real reason that one brake rotor should cost more or less than another. If there is no major difference, ie.. titanium alloy vs. steal. Of course the titanium alloy discs are going to cost more.texasoil wrote:The lowest cost brake rotors I know are for MBZ cars--and they are very predictable. Q45 rotors from O'reily's are <50% of dealer--but the parts guys are always surprised at how pricey they are compared to other makes.
WAIT! Everyone stop what you're doing!!!! Let's all go buy some Hyundai Excel rotors, because SOME GUY with a Caprice has Q-sized rotors!!!PoorManQ45 wrote:Some people think that because of the weight of the vehicle(4200lbs+), that the discs should be beefier. This is not true.
I have a friend that has a caprice classic(4500lbs+) and his rotors were approximately the same thickness as those from the Q.
AZhitman wrote:WAIT! Everyone stop what you're doing!!!! Let's all go buy some Hyundai Excel rotors, because SOME GUY with a Caprice has Q-sized rotors!!!
I thought I explained that OEM rotors and the ones that I have are the same thing. They're probably made in different places. Mine are made in china(nothing wrong with that), your's are probably made in Japan or the USAAZhitman wrote:You were comparing cheap Chinese rotors to cheap Chinese rotors. You neglected to compare them to an OEM quality/weight rotor.
You'd be right in that assumption.AZhitman wrote:I'm assuming you're a metallurgist, so i won't get into the materials issue.
If you didn't notice, I didn't cheap out, too much, on the pads. $75 for carbon-ceramic compound brake pads. They produce almost no brake dust, no noticeable noise, and the stopping distance seems just fine.AZhitman wrote:I know you desperately want someone to tell you you're right, but your bargain pads and rotors will cost you six feet in stopping distance
I do not cheap out on tires either. They are the only place that you car contacts the ground. I use Grand Spirit AquaFlow 225/50ZR16 their load rating is 1389lbs. They cost me ~$90 a piece. They're really great when the road is wet. Their dry traction is pretty good. They are a medium-compound tire.AZhitman wrote: (not to mention the additional six feet of stopping distance added by your cheap hard-compound tires).
4200lb car vs. 3200lb car, 4200lb car wins. I'm not saying that I would hit anybody on purpose. And, if the other person is the one that ran the red light, I get a big *** check from the insurance company.AZhitman wrote:That adds up to you punching a Q45-shaped hole twelve feet through someone's car that ran a red light.
Only $15 dollars in savings? I save $75 dollars every time that I change the brake pads. Lifetime warranty, you know. They will replace the pads when they're worn out, for free. That means that I have saved $150 on brake pads alone.AZhitman wrote:You can hand over your $15 savings to the grieving family.
You're correct. It has over 350hp. It's got a 350 police interceptor in it.AZhitman wrote:A Crap-pice Classic doesn't have 278 hp either.
I'm trying to help you guys out. I have personal accounts of what I'm talking about.AZhitman wrote:Remember, less posting, more reading.
I just used the Caprice classic as a weight benchmark.Jesda wrote:I would not use the stock 200hp overweight Caprice as a performance benchmark for anything. I loved driving it and it rode like a creampuff, but by no means should it ever be mentioned in the context of performance. Its biggest safety feature is that anything that it hits will be like driving over a squirrel. Take your living room, put it on four wheels, and make it move. Wallah! Instant Caprice!
I like the way the caprice rides. You can take a sbeed bump at 40mph and it just feels like you're riding a really long wave. Handling wise, it sucks big time.Jesda wrote:I loved driving it and it rode like a creampuff, but by no means should it ever be mentioned in the context of performance.
Caprice Classic =Jesda wrote: Its biggest safety feature is that anything that it hits will be like driving over a squirrel. Take your living room, put it on four wheels, and make it move. Wallah! Instant Caprice!
Very true. But actually, they are the same car with different engines, normally. Now, a caprice classic with a police interceptor motor in it is the same as an impala ssJesda wrote:The Impala SS on the other hand is another beast.
Don't know about the brand (Cooper?), but way under the OEM minimum load rating of 95 (1521 lbs.). Like AZhitman says, stay the hell out of my neighborhood.PoorManQ45 wrote:I do not cheap out on tires either. They are the only place that you car contacts the ground. I use Grand Spirit AquaFlow 225/50ZR16 their load rating is 1389lbs.
