texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Wed Oct 23, 2002 10:58 am
I have offered nine for $1500 as a special incentive to folks. A set of 4 strut accumulators would be more per unit ($200 each). My warranty is free replacement for one year, after that, 50% discount off of standard price at that time.
Obviously I wish to earn money doing this service, while encouraging owners to 'stay active.' I believe in these cars and the system.
If $175/accumulator results in more sales, that is what I will do. If it only means less money for the same number of sales, that does not help me any.
Comments anyone? Vote with orders please.
I did not hear from Sopadope about any deterioration in performance, or I would have supplied replacement units under the above terms or better.
To regain 90+% of original system performance, the strut and main accumulators need to be recharged. It would be difficult for anyone to detect by 'seat of pants' when the '90%' limit is reached because the deterioration is to 'standard suspension' performance levels. Only condition which would tax the system to that level is sustained large road surface undulations. Those conditions require the system to 'move' the wheels up and down a lot repeatedly, and the pump output accumulator may not have 'new' storage capacity, which would result in reaching the ultimate limit (the pump output rate) a little sooner. About 15% of the high pressure oil storage is in the pump output accumulator. If it is low/flat, the pump turns on sooner, supplementing the available fluid, thus resulting in about 10% overall loss in 'sustained rapid response' capability.
The two small accumulators on the valve assemblies are there to reduce/eleminate 'water hammer' noises during large system excursions like 'speed bumps', but they do not add significantly to the overall high pressure storage capacity. I would like for folks to replace them just to help protect the valve assemblies from the hydraulic shock.
