Q45 (Y33) Microfilter Replacement Instructions
xmateo
Car: 04 G35 Sedan
I just tackled replacing the cabin microfilter on my 99 Q45. It was easier than I thought it would be. And thanks to infinititech1 on his post "replacing a/c micro filter-g35" (zerothread/199424) I got some good tips.
Remove the panel (includes the trim peice) under the glove box. To do so, place your fingers in the holes in the panel and pull forward. It comes off fairly easily. It may be helpful to disconnect the floor light and other electrical connector, then remove the panel from the car so the glove box has somewhere to rest.
Remove the 3 screws under the glove box, and 4 screws found inside the glove box at the top. Pull gently and the glove box comes out. Let it rest on the floor as much as possible. There is no need to disconnect the wires (however I did initially because I wasn't sure where the filters were located).
Just to the left of center will be found two vertical plastic peices that almost look like a split ruler. (open your new microfilters and take a look at the end of them and you will recognize the ones currently installed in your vehicle). Remove the clip on the lower filter and pull to remove. The upper filter pretty much falls out.
Install the new filters and glove box/panel in reverse order. Voila!
I have a picture, but cannot successfully attach for some reason.
Modified by xmateo at 5:28 AM 12/14/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thank you!! If you email me the picture, ill host it for you... We're having problems iwth attachments.
Skibane
Car: 2000 Q45 AE 110K
That pretty much covers it.
Several items not mentioned in the instructions:
1. The two filters are identical - Either can be installed in either slot.
2. The upper filter isn't retained by a clip. IIRC, the back of the glovebox helps hold it in place.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
All well covered not only in previous posts, but also in the FSM.
Hello, IOM!
