how to: replacing a/c micro filter-g35
A general discussion forum for G35 and G37 owners and a great place to introduce yourself to the NICOclub G-Series Forums!
infinititech1
Ok well I've seen some very very dirty micro filters in some cars and even some with rats nests so I thought I would do a write up to help everyone out ... all you need is a phillips head screw driver.
1. Remove plastic trim piece on floor right inside the passenger door (it's right beside the door sill) just slide your fingers a little under it and pull up ... it's just clipped on.
2. Look under the glove box and you will see a black trim piece that covers the bottom of the glove box ... stick your fingers in the front of it and pull down ... this is also clipped on and will come off really easy.
3. On the very back of the passenger kick panel there is a little black plastic bolt that screws off from the kick panel ... unscrew it. Remove the kick panel ... some times it's hard to do without breaking the clips ... I usually just slide 2 fingers under it and yank out really fast ... some times the clips break.
4. Look on very bottom of glove box and the right and left side there are 2 screws ... remove these screws.
5. Open the glove box and remove all four screws on the top of the inside and sit all the screws together somewhere.
6. Pull down on the glove box and it will fall down ...
7. There will be wires hanging but I do all this without disconnecting wires or harnesses. Right above the blower there is a little white rectangle panel that you can pull off ... there might be a little harness in the way ... just push it up out of the way. There is a little raised up piece you can pull on the white panel ... pull it off. Boom there is your micro filter ... wiggle it out around the wires ... you may have to bend the filter.
For installation reverse the removal steps. You may have to bend the new filter around the wires which won't hurt it because it's so flexible ...
I'm just tryin to save everyone some money Sorry, I don't have pics. I did the best I could explaining it step by step ...
infinititech1
any questions...just ask
jhoke
Car: 2003 G35 Coupe
Thanks. Just did mine and you instructions are dead on.
thintzen
do you have the part number(s)?
thanks
jhoke
Car: 2003 G35 Coupe
Ordered mine from Everything G35. Didn't need the number.
infinititech1
umm...don't know it off the top of my head but if u want i'll get it monday...i actually had a few extra ones somewhere
thintzen
that would be really nice of you, the only reason i ask is that i can get it directly through nissan through my contact, rather than pay list price.
infinititech1
hey its a sticky
infinititech1
i'll try to add pics soon
Dumb question:
Does my 03 G Coupe have one?
infinititech1
yessir it does...i actually have a g35 one sittin in my garage
JHPIV
Car: 2005 G35 Sedan
Just replaced mine tonight...took about 25 minutes. That included about 5 minutes hunting down the screw that fell under the carpet, (dumb move on my part), and about 5 minutes trying to get the glovebox to pop loose without breaking something! Thanks for the instructions!
g35ivp
how often should u change ur filter?
infinititech1 wrote:yessir it does...i actually have a g35 one sittin in my garage
Thanks bro!
Will swap it out before "allergy season"!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
g35ivp wrote:how often should u change ur filter?
On the full stacked HEPA filter on the FY33, I do it annually along with the engine air filter.
Sounds like the FY33 filter is quite a bit larger.
Good write up, infinititech1.
kmech_7
Car: 2003 Infiniti G35 coupe (Skyline) Vortech Supercharged Jul 08 ROTM
Ok... so the line (a/c line) on the right side of the engine is leaking. its the small one. The one that passes the intake. what is the lines corect name and how much does is cost to fix (by the dealer and by me) If its easy to fix and hassle free ill do it but im sick of wasting my time on these bs problems...lolthanx to all that can help me!!!
G_whizz
Car: 2010 G37 Coupe Sport
Try posting here zeroforum?id=24
You will get a better response!
Crashtest77
Car: 2003 G35 coupe
Haha,if I drive down to you infinitech will you do it for me haha. j/k
infinititech1
lol sure...actually i have an extra one
fatire_mtb
Car: 2004 G35 Coupe 5AT
Thanks for the how to. I changed mine this weekend and it took at most 15 minutes. I don't think the filter had ever been changed based on the funktatude of the outgoing filter.
Next up...JWT Popcharger, Z tube, 5/16 plenum spacer and borla exhaust, bumper lower grill inserts. Hopefully all the parts will be in by this weekend so I can get started.
telcoman
Infiniti Tech. Thank you for the instructions. I replaced mine today with 25422 mi on my 2006 G35 sedan 6sp manual. It took about a half hour including the pictures that I took. i hope I don't screw up trying to copy the pictures. The first dealer that I went to for the cabin filter refused to honor my Infiniti discount card (Ray Catena) so I went to Circle Infiniti where they not only gave me my discount ($29.45 for the filter) but saved me over $3000.00 on my purchase of the G35. Go Circle Infiniti!. The factory Cabin Filter also comes with instructions. The only tool needed is a #2 Phillips screwdriver. I'd be curious to know what the dealers are charging for this simple Cabin Filter replacement?
TelcomanEast Brunswick,NJ
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I need help posting the pictures
Modified by telcoman at 9:25 AM 4/14/2007
infinititech1
they charge .5 labor which is about 50 bucks plus whatever the filter is...any one need a micro filter?
805g35
Car: 2003 infiniti g35 coupe
infinititech1 wrote:any one need a micro filter?
If you've still got one i'd love one. I'm arip609 btw.
joas007
Car: G35
is ok when u break on g35 the abs vibrate under ur feet?my sedan is make noise i break when i go over 80
AMAG35
Car: 2006 G35 Sedan
Do you still have a filter available?
jetjoc
Car: 2003 m45
Same for 03 m45 and what about under seat filters?
infinititech1
umm...everyone email me that wants one...first ones that said they needed one get first dibs cause i think i only have like 2 or 3. [email protected]
joas007
Car: G35
hi I'm new at this I need some helps please
on you decriptions you said" you need remove the kick panels is there a reason why I have to remove them if the micro filter is under the glove box. if so what is under the kick panels?
thanks
infinititech1
it has to come off to get the glove box to drop
telcoman
Although i just changed mine and took pictures, so far I've had difficulty trying to post them and i need assistance on exactly what I need to do to post them?However, as far as changing the micro filter, print out Infinititech's excellent instructions so you'll have them in front of you.
Item 3
If you pull up the carpeting on the passenger side, you'll see the two plastic nuts that you will remove by hand.
item 7
If you bring the passinger seat up closer to the glove box it will make it easier to rest the glove box after removing the screws. Looking above the round blower plastic housing you will see the rectangular piece that pops off exposing the micro filter.Before removing it, note the position of the writing on it and orient the new filter the same. Remove the old one & insert the new one.The filter that I purchased at the Infiniti dealer came with instructions including pictures. The whole job took me a half hour including taking pictures. After the next 25k miles it'll probably take me 15 min. The only tool needed is a #2 Phillips screwdriver. Very easy to do. Thanks again to Infinititech for his instructions. I hope this helps you.
TelcomanEast Brunswick, NJ
Return to “G35 and G37 General Discussions”
