Q45 Subwoofers
revil86
Car: 1993 Infiniti Q45
1993, which way do i face it?
PoorManQ45
I see.
Take a look at this:zer...age=3
That's for the G50. What do you think about that setup? Not much phase cancellation occuring there
*edit* In a few days i'll start copying it and selling the enclosure to nico members. More then likely i'll cover them with carpet rather then paint
revil86
what? the fiberglass boxits nice but how big of a sub can you fit in there?you got a ballpark for a price?how would one secure it to the trunk so it dont go flyin around?
PoorManQ45
Currently it's made for a 12in and smaller sub. If I pushed the front of it out more I could mount a 15 in there if you so desired.
Price: I was thinking in the $200 neighborhood. I personally think that this is on the low end of the price scale. If you don't believe me just take a look at Q-logic boxs.
Well, like rex said, it's currently using the "tension mount" holding method, also known as "push it until it stays". But I could attach some velcro to the back of it to make sure that it stays put. I don't really think even that is necessary though because it's a pretty tight fit to begin with
nchopp
How much work would it be to flip the design around so you could have one on the driver AND passenger side?
heywier427
Car: 91 Q45
ive got 3 12 inch fosgate dvcs in the trunk and 2 10 inch solor barrics where the 6/9s were. to get the sound into the car i cut out the map box and covered it with a mathing carpet looks sweat sounds even better. ive won many sound comps in ct nj 168 dbs max broke the b window once and have to drive with the sunroof open!!!!
PoorManQ45
nchopp wrote:How much work would it be to flip the design around so you could have one on the driver AND passenger side?
Oh, not much. Just have to redo the whole process, starting with the masking tape. If that's what you absolutely wanted I could do that for you, but unless more people would be interested in that setup I'd have to charge a little more
heywier427 wrote:ive got 3 12 inch fosgate dvcs in the trunk and 2 10 inch solor barrics where the 6/9s were. to get the sound into the car i cut out the map box and covered it with a mathing carpet looks sweat sounds even better. ive won many sound comps in ct nj 168 dbs max broke the b window once and have to drive with the sunroof open!!!!
Um... What are your mains? If you tell me stock I'll have to hurt you
revil86
how could i get 10s to fit where the 6x9s are? and where could i get some carpet like you used?
PoorManQ45
You would have to cut the metal of the rear deck. OR you could mount the 10(s) raised slightly above the rear deck with the magnet structure sticking down through the stock 6x9 hole. I personally would go with the latter method as I wouldn't want to compromise the vehicle structure. YOu could probably get away with mounting it/them about 1~2in above the deck. That'd give you enough clearance, and maintain visibility. Not you'd have to have some descent fabrication skills as you would have to rework the entire rear deck cover.
As for the carpet. Look in the phone book under automotive. Specifically automotice textiles
revil86
rework the rear deck cover? what do you mean?o and where's the best place to run an amp wire through the firewall of a G50? with or without drilling?
nchopp
PoorManQ45
revil86 wrote:rework the rear deck cover? what do you mean?QUOTE]If you mounted the sub above the deck like I suggested you'd have to use something to build up the area around it so you'd have something to mount the driver too. I personally would you fiberglass and fleece combined with a MDF ring.
Doing this would make it so you couldn't use the rear deck cover though. So you'd have to make a new one. You do it the easy way and use carpet for this
revil86 wrote:o and where's the best place to run an amp wire through the firewall of a G50? with or without drilling?
I don't know the answer to that(guy below linked it), but I've found it very easy to just run the wire outside of the car, along side the fuel lines.
revil86
nicei was thinking about using fiberglass to make a mold of the old rear deck, but i have no experienceit looks like this could be a good time to start
revil86
o yeah, i was taking a look today at the space where the map box used to be and perhaps an 8" sub can fit in there, no?
PoorManQ45
yep, it could fit.
If you don't want to have to make an enclosure for it you should get a sub that's designed to run in an Infinite Baffle setup
revil86
infinite baffle setup? is that like a free air sub?
PoorManQ45
well, free air doesn't have a baffle at all. Meaning the driver is just sitting there not mounted.
Infinite Baffle uses a baffle(mount) for the driver, but no enclosure for the rear. It is open to a large volume of air. The front and rear waves should NEVER come in contact though or cancellation will occur.
revil86
o, i got you nowi guess thats the best way to mount 8" subs in the rear
PoorManQ45
well, it's the easiest way to mount them. To some this is the best way, to some it is not.
I personally like the way IB subs sound. They are very "open" with none of the normal nuances found with standard enclosures
revil86
nice
PoorManQ45
One of the "Drawbacks" that alot of people see in the IB setup is that you don't get too much "oomph" from the sub. Let me rephrase that, you don't get as much "oomph" as you would if it were in a normal enclosure, but obviously this is natural sinse there is no constant airspring in an IB setup.
ANyways, an IB 8 in the rear deck would be a good addition
revil86
i wanted to use the BOSE amps from the rear speakers just as an experimentis that a bright idea?like using relays and the remote turn on lead from my alpine radio
PoorManQ45
you can do that. I think you'll need a converter from PAC to use the bose amps though. This is the easiest way.
revil86
i heard my mechanic suggesting a four prong bosch relay. can i use that?
PoorManQ45
yep, that'd work.
You'd hook up constant power to the relay, and then hav ethe relay switched on and off by the remote turn on from the HU.
Then you have to send the actual signal to the amps.
revil86
you mean like a line out converter?
PoorManQ45
I don't know exactly what type of signal the bose amps use
It's probably a standard RCA signal without the ends. Each side has a signal and ground line
revil86
im gonna try to use the HU rear speaker signals this weekend, maybe there will be prgress
PMQ, thanks for all your help and allyou are the man
PoorManQ45
hopefully that works. I'm not too sure about the signal part though. The power part is easy.
I would recommend that you take a cheap RCA cable long enough to reach to the trunk, and cut the ends off of one side. You'll notice that within each cable there are two wires. Oh yeah, first note which is left and right. Strip back some of the wire on both the rca cable and where it connects to the amp. Then just for testing twist the wires together. Meaning left ground on cable to ground on left amp, positive to positive, and the same for the right side. Then try it out. After you hook up the power relay of course
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Hello, the signal from the factory Bose headunit is a preamp signal and it is rather fragile. I wouldn't use a line output converter because those are designed to "Cut" the speaker output of a amp down to preamp levels. You could use one on the output of the Bose amp but thats kinda silly. I recomend checking out davidnavone.com and get a N-686 heres the link http://www.davidnavone.com/adaptor_products.htm This will give you the transformer isolation you need to keep noise out of the system and to keep the stock preamp section from shutting down. It has regular "Speaker wire" in and out and I would put female RCA ends on the outputs and then plug what ever length RCA cable you need to your amp. This way you will get maximum signal into your amp and the lowest chance of noise and pops and stuff.
Good Luck Scott
