those upper control arms(front) go out pretty regularly. side note, be sure to use a spring compressor that is in good condition. at the shop i used to work at we had a crappy one. it came apart on me and the spring hit me in the chest. the guy watching the whole thing said he thought i was dead. im pretty sure my survival qualifies as a miracle.:icesangeljpdavis423 wrote:I also want to replace any part that might need it. Has anyone developed a complete parts replacement list for doing a "strut" job. Also since I don't have the shop manual can anyone give me the torque settings for the various nuts and bolts?
Thanks in advance
s13sr20chris wrote:side note, be sure to use a spring compressor that is in good condition. at the shop i used to work at we had a crappy one. it came apart on me and the spring hit me in the chest. the guy watching the whole thing said he thought i was dead. im pretty sure my survival qualifies as a miracle.:icesangel
Nothing - the strut assembly will be easy to wriggle out of the wheelwell. The spring is not exerting any force on the car body or the suspension. It is confined to the upper and lower strut perches.OneTimePoster wrote:ok so car is jacked, I remove lower bolt (thinking optimistically here), then ?while car is still jacked up???? I remove top bolts (and strut)? What happens to the car?
I'm confused here. You need to jack the car up (front or rear) and put it on jackstands before you even start this job. How about you call me at (602)828-8908 if you get confused and I'll walk you through it.OneTimePoster wrote:I totally don't get what is being jacked up and what isn't when the top bolts are off .....looked very weird when I was jacking it up. Half the car was moving up and the other half wasn't.
OneTimePoster wrote:TOP strut nuts loosened pretty much all the way to the top.
