IanS »
https://forums.nicoclub.com/ians-u23642.html
Sat Feb 21, 2009 12:05 pm
No you cannot use stock S14 rotors. The size difference is huge.
Why do you need aftermarket rotors? Unless you've built an all out track car, then blank rotors are better than anything you will need. There is no reason for slots or drilling with the Q45 setup.
If you have your heart set on some showy rotors, I believe some of the Z rotors are the same.
