q45 radiator
natsoundup1
the radiator is out...I am going to take some pics and go to work to post them... i can't do it on my home computer/.
it could boil down to measurements... I don't know.
there are three fittings on the driver's side of the radiator.... two for transmission coolant...one for temperature...plus of course the lower radiator hose..
I'll try to take some measurement to include in the post.
Radiator is leaking from the passenger side where the plastic meets the metal...there's a place up top and another at the bottom....oh well what can you expect for 167k miles and 14 years.
Modified by natsoundup1 at 8:25 PM 11/20/2004
natsoundup
oops...don't know how to post images on this forum...will send them directly. Wes...e-mailed...
Dr Q I need your e-mail address... mine is [email protected]
Modified by natsoundup at 5:42 PM 11/20/2004
DR.Q
I sent you an email with a photo attached. A BIG photo.
natsoundup1
sent you some back.
natsoundup1
can measure the rubber grommets on the bottom....center rubber to center rubber..
and the radiator across the top of the aluminum
DR.Q
Center to center is 27" exactly.
natsoundup1
that's what I came up with....
do you also have two transmission cooler lines.. and a temp line on the drivers side... and are the fittings intact for the cooler lines?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I got your email...
I have 4 things for the transmission cooler......
natsoundup1
wes--- is it too on each side? there are definitely only 2 fittings on the driver side on mine...like i said...plus the temperature sensor fitting...
maybe that's the difference between a 94 and a 90
DR.Q
natsoundup1 wrote:that's what I came up with....
Two ATF cooler lines on driver's side only...a temp line on the driver's side with sensor and harness...and the fittings are intact for the cooler lines.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
natsoundup1 wrote:Radiator is leaking from the passenger side where the plastic meets the metal...there's a place up top and another at the bottom....oh well what can you expect for 167k miles and 14 years.
Sounds to me like the tank gasket went, which can be replaced by a radiator shop.
natsoundup1
Dr. Q is going to hook me up..I may check into the radiator shop...I did one today...and they say it's cheaper to replace them..
I really don't expect much more out of this Q, so it has to be used parts....or else I'll be parting it out ....
