VH41DE ... difference is the manifold design between the VH45DE.S14tat wrote:how much power did the VK45DE of yore made?
I'd have to disagree with the 100 lb. difference but regardless, it's a cool swap to do.freethinker wrote:No, it won't be a drag only car. This engine weighs about 100lbs more than a KA but it will be the only thing in the engine bay, and it won't have any accessories other than the alternator. This car will have better weight distribution than a stock 240, trust me. Read some of my old posts to see how much of a balance nut I am.
S13CoupeLuvr: You'll prolly like the fender flares I'm using on the car; S13 N2 factory replicas. (the ones on the car in your avatar)
-Sean
He photoshopped the S14 front end onto the S13 coupe. If you look where the hood meets the rest of the car you can see it doesn't line up.AZhitman wrote: ...Oh, and I don't think that GP car pc is photoshopped, but I could be wrong.
The block might weigh the same as the KA's iron ... but weigh the extra head, pistons, rods, crank material, thicker girdle, heavier crank pulley, additional main bolts, head studs, exhaust manifold, oil capacity, coolant capacity, additional fuel setup, etc. etc. etc.AZhitman wrote:freethinker - You won't hurt photopost, we have more bandwidth and usable storage space than you could ever fill.
AND, a humongous badass server.
Project looks great. Ambitious, but fun! Pop into the Infiniti General area and show those guys...
Actually, the estimated 100 pound difference in engine weights is probably pretty damn close.
Remember, the VH is ALL aluminum.
Glad to have you here at NICO. Welcome.
Oh how I wish..... but the N/A Z32 flywheel was a bolt on and has the same exact ring gear as the Q45 flex plate, scored 1 there.chandler wrote:so te z33 transmission bolts up or is that just to easy? also , why not use the power steering?
That's not asking too much really... sub 3000 is simple, weight distribution might cost a few pennies to move everything and lighten up some stuff.freethinker wrote:Damn the critics, I want sub-3000lb wet and better than OEM S13 weight distribution.
I think you would be better off with a LS1 or LS6 if you want a chevy motor. As far as I know the 6.0 motors are all iron and that will be one heavy mofo. The alum. small blocks are actually lighter than the Q45 engine since they have 1/4 the cams and much smaller heads, and they can make the same power, plus there is probably a better aftermarket for them.elesjuan wrote:DAMN IT!!!!!
I've been working on a modified LQ9 install into my 240, but I haven't put together the entire motor yet.
freethinker wrote:I have pictures of a purplish red S14 with an LT1...
Aries wrote:looks like a fun project
