Hes right..... Its located in the middle ish, youll see it... Thats the only one what will pertain to you, there are others that are required for engine removal....Squeefoo wrote:Electrical connector: The circled w/yellow bolts do not need to be removed, just the connector. On mine it appears to clip in approx. the middle of the car, follow the wire loom from the picture to the end where it clips.
1. Yes.. I just loosened both err took them out, and when I lowered it down it came right off... Just spray some of that lube stuff on there and youll be fine... It goes on MUCH easier than it goes off, but we will have to make sure you get your steering wheel aligned right, as thats something I messed up on Jesda's car... When we get to putting it back togther, i will expound...Tangalora wrote:Q1: Is my assumption reasonable that removing only the lower bolt of the steering lower joint will work? I couldn't get the upper bolt off. I'm assuming the crossmember is heavy enough to pull the lowest shaft out of the joint at the bottom.
Q2: It remains to be seen whether the engine gusset really has to be removed (I'm hoping I can get to that last hidden oilpan bolt from the side once the crossmember is moved out of the way).
Q3: How on earth am I going to keep the crossmember from falling down if I do not remove the steering rack from the crossmember (should I just bite the bullet and remove the remaining four bolts holding the steering rack to the crossmember?) It seems the crossmember, being very heavy, will be in my way the whole time I'm working on the oil pan if I don't remove it from the car.
I already removed all the plastic on the cowl (for the third leg of the engine support) and I removed the fan shroud (to get to the alternator & belts).elwesso wrote:Bascially an extra 30-60 mins TOPS just to remove various connectors, fan shroud, and so on...
I dont see no photo. I'm curious too where these bushings are. My steering wheel shakes like the dikens on the freewya. Can you post photo again to help me.elwesso wrote: just replace the bushigns on the OUTSIDE. attached is a photo helping you out...
Your diagram helps immensly! I'm glad the steering rack doesn't have to be taken apart.elwesso wrote:Steering rack bushings are attached to the OUTSIDE of the rack... You wont have to take apart anything on the rack... just replace the bushigns on the OUTSIDE. Attached is a photo helping you out...
Your correct, they are the same bolts.. But due to the placement, you cannot replace the steering rack with the cross member in place... The bushings are cut so that you wrap them around the rack...T wrote:Is the photo below correctly pointing to the passenger side "rack mounting insulator"? I'm still confused because it appears the two bolts holding the rack to the crossmember are the same bolts (are they?) holding the u-shaped brackets holding the steering "rack mounting insulators". ??? Or does the rack mounting insulator get removed some other way (presumably they are doughnut shaped so something has to give somewhere to remove them).
Q45Tech recently described it's operation. I forgot.tangalora wrote:
P.S. I do see the electrical connector previously mentioned. Thanks for that admonition to disconnect that. I wonder what it controls.
OK, I think I've got it. I want to mentally rehearse the steps for the actual removal of the "iron cross of death" before I do anything brash. What's been confusing me about the steering rack bushings is that the steering "tie rods" are still attached to the wheel (I think) so that rack isn't going to go anywhere (it seems to me) but flop around when I remove the crossmember --- yet the steering rack won't even flop around as it's boltd to the crossmember. Does my dilemma make sense?elwesso wrote:Tang.. you wont be replacing until the cross member is OUT of the car... You're correct, they are the same bolts.
Like I said before the steering rack WILL REMAIN ATTACHED TO THE CROSS MEMBER!!! You will replace the bushings when the cross member and its related components are off the car..... Everything susupension and steering related is bolted to the crossmember, so it will come off...tangalora wrote:OK, I think I've got it. I want to mentally rehearse the steps for the actual removal of the "iron cross of death" before I do anything brash. What's been confusing me about the steering rack bushings is that the steering "tie rods" are still attached to the wheel (I think) so that rack isn't going to go anywhere (it seems to me) but flop around when I remove the crossmember --- yet the steering rack won't even flop around as it's boltd to the crossmember. Does my dilemma make sense?
How can I remove the crossmember without removing the steering rack if the steering rack is tightly bolted to the crossmember? It doesn't seem to make sense to me (but I might be missing something that is obvious to you).
I was hoping to finish this job this weekend and do a write up with photos for the next person to sail right through, but a family emergency came up and I have to fly to Kennedy tomorrow morning so, I won't be back on this 'till all the turkey day leftovers have been eaten and we begin the new week of work.
Thanks guys ... I'll catch up with you when I get back.Tang
Those two mounts are dangling teasingly (tauntingly) right now.I don't know how to remove them from the engine.Since it's not oil pan related, per se, in an existing separate thread http://www.nicoclub.com/zerothread?id=1963 (www.nicoclub.com/zerothread?id=1963) I appended a question on how best to remove the last (top) nut on those two dangling motor mounts.Wes wrote:While the crossmember is out, you will replace things like the motor mounts and the steering rack bushings...
Any time. The whole reason I take a thousand photos per job (sunvisor, fuel pump, brakes, etc.) is to help others do what I couldn't (at first) do. In my opinion, you guys do all the work by answering my (sometimes stoopid) questions. I learn from you. In that spirit, I plan on typing up the writeup I've already handwritten on the back of a printout of this thread for a complete oil pan R&R. That way, everyone after us benefits from our efforts. Of course, I'm not done yet - still peeling the onion - and finding (undocumented) surprises - but, together we'll get there (I hope) after the last few stumbling blocks are overcome (see below).Wes wrote:I'd really appreciate an article we could use to put on Q45.org and also on NICO...
I wish it were that simple (or am I doing something wrong?).This oilpan R&R is (exasperatingly) sort of like peeling an (undocumented) onion.Wes wrote: ... Basically all you have to do is unbolt the member from the car, drop it down, DROP THE OIL PAN, replace the oil pan and other components (hopefully the oil strainer isnt bad), and then put it all back together....
Hmmmm ... the front engine crossmember is now out of my way (I think). See the photo below where it is dropping down held to the Q45 only by the steering rack, steering hoses, and steering tie-rod ends (I think).squeefoo wrote:the outer tie rod ends must be removed from the steering knuckles, in order to properly lower the suspension member.
Q1: Does hanging the x-member on the steering cause too much stress?A1: I have no idea. Should I remove the rack immediately to prevent further damage? I suspect all I'd need to do is remove the four bolts and the x-member would pop free (I don't think I need to remove the tie rod ends anymore ... aren't they connected to the rack & not to the x-member)?DAEDALUS wrote:How heavy is the x-member?What about stresses on the rack/seals.Is your Q raked at a steep incline
I did NOT know that!squeefoo wrote:Not sure if you know the tops screw up and down on the bottle jacks.
That is correct.. This is ****perfect**** time to replace your rack bushings.. Go ahead and seperate the rack from the member, and it can dangle there. Its just a tube, couldnt weight much at all, the hoses could hold it up anyway... Personally, if I had to chose, id figure out a way to remove the member from the car, and set it aside... You have enough crap to work around as it is.... Id even say its worht replacing a couple hoses if you have to cut it (just not the expesive Hi Pres hose with the screw on fittings)squeefoo wrote:I mentioned the tie rod ends since Wes said it had to stay on the X-member, I originally thought the bolts could be removed and let it hang -as you see now. It depends on whether you can/choose to work around it. It would be easier to remove the 4 bolts holding the rack on and let it hang, it wont hurt anything.
The transmission gussets are there to reinforce, not hold the trans. on, there should be no problem taking them off to get to the pan bolts.Not sure if you know the tops screw up and down on the bottle jacks. A piece of 2x4 laid just behind the work area will "catch" the rolling tools, saves a lot of up and down, off and on the creeper. You're doing well.
elwesso wrote:If I had to chose, I'd figure out a way to remove the member from the car, and set it aside ...
Believe me, you will take SO much pride in driving your beloved Q, knowing you fixed it sucessfully.. Thats why I missed (and still do) my old one so much.. Literally, my blood is on that car, and I put a lot of work into it.!!! Hang in there, and in the words of the cable guy, git r done.....T wrote:You're perceptive. I really do wish I hadn't started this. Dennis was right. It's a big job. (Maybe not for Byron at T3, but certainly for an inexperienced amateur like I am). Anyway, about the only thing still keeping me going is you guys helping me out. It's wierd. I don't want to let you down (and the next poor soul with the same problem). It's kinda' sobering. All my friends are telling me to cut my losses & get rid of this sick bleeding Q ... and wierdly ... you guys are the only ones who really care to bring our beloved Q's back to life.
