I kept my eye on the gauges very closely. Not a blink. Even the coolant remained steady (long ago, in my 280Z, I merely left the oil filler cap off and the resultant coolant temperature rise was what told me I had a problem which was solved by replacing the oilfiller cap). No funny sounds whatsoever.
I don't know how to tell if the 1990 Q45 oil pump pickup is damaged; is there a simple test? Since the oil pan seems punctured only on the corners, I'm going to hike down to the parts store today to see if the gas tank putty will work. I vastly prefer to have a car this week (life seems so much more hectic without wheels).
That's bad news about the "suspension crossmember " having to be removed first. But, maybe that's hidden *good* news in so much as I'll learn more if I find I have to remove and replace the Q45 oilpan. (I circled in the photo below what I *think* you mean by the suspension crossmember.)
If I rent a winch for a day (I've seen them outside the parts stores on the sidewalk for years) - I think it's called an engine winch ... where do I hook it up to hold the engine from falling down? Can't I just support the engine from the bottom?
Once I hold the engine up, if I just unbolt the "suspension crossmember", can I _then_ directly access the oilpan for removal? (I'm still in shock so I didn't yet check with Joe on how much just a 90 Q45 oilpan costs nor if he has it in stock over there in Scottsdale ... but I'll get to it today or Monday after riding my bicycle to work.)
Where are the Q45 motor mounts?
I hopped under this morning to look for rubbery "capacitors" (At college, long ago, I once 'assisted' on the repair of a 70's Dodge 318 V8 with both mounts chopped in half (well, I prepared lunch, which in those days was probably just beer, wine, hot chocolate and pizza)
We simply put the car on ramps, supported the engine with a floor jack, and unbolted the old motor mounts (which were as simple as two metal plates with bolts, sandwiching an inch-wide rubber tongue.) The hardest part, if I remember correctly, was the weather, with wind & rain at about 40 degrees or so (no snow luckily) and losing the sunlight an hour or two before cleanup on a busy side street.
The comp coverage was a good idea I hadn't thought about. It won't work for me (nothing but liability for years) but it might work for other readers out there, so I commend the suggestion.
I'm kinda' depressed in that I really didn't plan for this ... but I'm trying (slowly) to come to grips with myself to solve this (yet another) stumbling block.
