FarFetched wrote:The colder the air the more adjustments are made to compensate for dense air passing MAF thus increasing demand for fuel - Good for racing - bad for daily operations
texasoil wrote:BIG mistake to pull air from the engine compartment (hot, low pressure, dirty)
OK, which is it? better fuel economy because the air is hotter, or worse fuel economy because the air is colder?
My K&N pulls air from the engine compartment, hense it is warmer. I believe Layla gets a little better gas mileage as a result. I am sure that the power is reduced as a result. I definitely get MAF failures much more, due to the filter oil. All it really does, is make a loud growl when I get on it. It actually makes people do a double take when I get on it.
I would suggest not putting one on your car. Stick with stock.
