Alright guys, I know this has been posted a few times before, but I can not seem to find a definitive answer.
I've got the brake calipers from a 90-96 q45 out of a junk yard, and I know that the lines/banjo fittings will bolt up to it just fine (at least from what I hear). However when I tried to bolt the calipers up, they just wouldn't fit. I've read somewhere else that you need the mounting brackets for the calipers, but in a couple threads (
http://en.wikibooks.org/wiki/N...rakes and
zerothread/316293 ) it doesn't mention anything about that. Some threads mention the need for the caliper bolts off the q45, others do not. Can someone please straighten me out on this one?
I also know that I need to use SS lines as I'll need to trim the heat shield/splash guard/whatever you want to call it. I'm just stating this for the sake of the thread so when someone else searches for it, they have the full answer.
Also the issue of the q45 rotors being 5 lug comes into play. I know that my options are to either convert to 5 lug, redrill the rotors to 4 x 114.3, or use 94-00 altima rotors (plus shims because the altima rotors are 6mm thinner, correct?). I just want this part verified.
I don't mean to beat a dead horse, I just want clarification so I can get these things on and going.
