KS are going to read in the 500k-550k Ohms resistance range or they're going to read zero. There will be no in between.Mint Q45A wrote:What would a higher resistance mean? How would it affect the performance of the car?
silkysmoothyjud wrote:The job is finally done!! Three weekends and totally freakin worth it!!! The car makes more use of its power with new ks. No cel (yet) and another thing, no strange smells in wot. That under plenum hose and gasket work has totally paid off. Also, the egr valve, one should check the connection on the exhaust mani to make sure its secure. Mine was about to fall off from just moving it back and forth. A big thank you to Wes for his unwavering support, and to q45 tech for his advice....75 mph no problem in second gear and very loose in all gears again, it wont hesitate to red line!!
thanks for the info . I been fixing my car with my friend , and every time we find something wrong wit the car, we have this codes 14 & 34 and i replace 2 times the speed odometer sensor (use ones ) and still is not good , i have speed odometer problems, but i hope the KS helps + a new speed odometer sensor,Q451990 wrote:Both sensors are the same. I would replace the knock sensor sub-harness, as well as any deteriorated rubber hoses under there - probably all of them if the plenum hasn't been off in a while.
Heath
