thanks for your help i will do it in 2 to 3 weeks . i hear some says that there is a KS KIT?Q451990 wrote:Not for the knock sensors themselves, but there are plenty of things that will need replacing. Check out some of the "plenum" threads, or just order what you need after you pull it apart...
At a very minimum, I would replace the throttle body gasket, and the plenum to runner o-rings if they're brittle. You will also want to replace the cooling hoses that cross between the heads, since you'll have to remove them to get to the sensors.
Heath
also about the problem with my speed odometer , i also need to replace the Rack and Pinion , is there any sensor?
i read this info
The Vehicle Speed Sensor (VSS) sends a signal to the speedometer and from there to the Power Steering Control Unit. So if the VSS has gone bad, it would kill both the speedometer and power steering.
thanks ;-)
