elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Jun 26, 2003 4:05 pm
Quote »drove a sts before buying my Q,,,,talk about a car with nervous torque steer!!! the power of the engine is great, but it all just "feels" wrong. the quality is also crap, especially the interior.
I had a post a while ago about gm's decision to go with front wheel drive, something about them not having a strong enough trans for rear-wheel drive or something(maybe you answered that one elwesso). if this is right, what about the corvette trans or camaro? maybe someone can give the definitive answer on the reason for front wheel drive?!!!jeff [/quote]
There are people that do drop in the camaro transmission, and it does OK, but the hassle is worth more than the car itself....... The dimensions are different, so finding a rear-end is hard........ The northstar has been used in other cars, though........
Id really like to drive the XLR, with the RWD northstar......
I like the cadillacs OBD better..... You can access all codes, test all sensors, and even change settings right from the DIC......
And if i did get a caddy, it would be a fleetwood (LT1 RWD, its the only way)...... I have driven my parents GTP and a vue, and with all that torquesteer, its great to get back to good ol RWD!!! And, there is a basically unlimited aftermarket, since it shares the aftermarket with impala SS......
Quote »Other than oil consumption, a problem which affects some northstars, the car has been a workhorse that's VERY cheap to operate. It doesn't even take premium.[/quote]
And the oil consumption-- the engines dont really burn the oil, but believe it or not, it "uses" oil........ The oiling pattern is much more aggressive than most engines, meaning that it gets better lubrication, but that does mean it uses more.... I can go into greater detail if anyone cares.......
The older northstars required premium..... They took premium up until 98 or 99, i cant remember for sure.......
Believe it or not, all of the 90s cadillacs (Seville, eldorado, deville) were all built on the same chassis...... They had the same drivetrain, same almost everything.... There are some differences, but they are basically the same...... The eldorado is only about 4in shorter than the deville......
