Q is deceased.
konatown
Car: 1994 Infiniti Q45t
2010 Genesis Coupe
As of this evening my Q45 is gone the wayside. Came out of circuit city, started the car and put my new CD in. As soon as I put it in gear, I hear a very loud and disturbing pop-thunk sound, engine died after that.
Haven't had my mechanic look at it, but that indicates a detonation or broken piston/rod?
konatown
2010 Genesis Coupe
Also, Wes do you know of any Q45's for sale in Indiana or near me?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You can buy my Q ..
I havent seen any Q's recently for sale...
Will the motor crank over? Or is it seized totally? I dont see how you could have detonated it that bad at idle, somewhat randomly.
konatown
2010 Genesis Coupe
Will not crank at all, makes a horrible noise if I try.
I recently had a misfire in a single cylinder, just replaced plugs and that coilpack.
That misfire overtime would've weakened that cylinder?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So sorry to hear.
This is something strange and never heard before as far as I can recall. I hope the starter solenoid didn't release or something easty to repair.
elwesso
2007 BMW M Coupe
I wonder if you were dumping fuel and you hydrolocked that cylinder?
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
Great point.
konatown
2010 Genesis Coupe
elwesso wrote:I wonder if you were dumping fuel and you hydrolocked that cylinder?
That is also possible.
konatown
2010 Genesis Coupe
Good news, got it ripped apart and the injector was the fault. Dumped fuel in constantly. Purchased a used one from the only other Q owner I know of in town.
Everything else looks fine, but has not gone through a professional inspection yet.
goody90q45
Car: 1992 Infiniti Q45 (sold)
konatown wrote:Good news, got it ripped apart and the injector was the fault. Dumped fuel in constantly.
I've had hydrolock twice, both of them pretty soon after buying my Q. I shared your pain when I read your post. I remember the clunk noise I heard the first time- I thought I'd thrown a rod.
I've got a feeling the previous owner had the fuel rail out of my Q just before I bought it. My experience both times is the lower o-ring gives out and floods not only its cylinder but all 4 in the bank. The fuel injector (FI) was still good, just needed a new o-ring. To be on the safe side you should remove all 4 plugs on the bank with the bad FI, let all 4 cylinders air out for a while (overnight) and then with the fuel pump fuse removed crank the engine for a few seconds without plugs to flush all the excess fuel out.
If you're a risk taker, the engine will probably turn over on its own after a couple of days of airing out without doing anything. After fixing the suspect injector, take out the fuel pump fuse, and turn the engine over for 10-15 seconds. If it's still hydrolocked then remove the plugs to air it out more but if it cranks put the fuse in and try it again. It should start.
Whichever way you decide to go expect a lot of white smoke for a few minutes when you do get her started. Good luck.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
konatown wrote:Good news, got it ripped apart and the injector was the fault. Dumped fuel in constantly. Purchased a used one from the only other Q owner I know of in town.
Used injectors are worn injectors. While your installation may have been at fault, used injectors are a wear item and should be avoided like used underwear.
konatown
2010 Genesis Coupe
Its just temporary, my only car. Its needed!
elwesso
2007 BMW M Coupe
I dont condsider injectors to wear out. Tech's Q has 320k and his injectors are original, if they havent worn out by now by his standards they arent wear items....
If the used one has good ohm and flows good, then theres no reason not to use it.
heywier427
Car: 91 Q45
whats the secret??? i use good gas and 44k every oil change. ive changed all 8 when the first 2 went bad 120,xxx. although i was not the org owner and the car came from cali. that gas makes that much of a difference?
Rex
Car: None
heywier427 wrote:... that gas makes that much of a difference?
Cheap or ethanol "additive" gas does make that much of a difference. On top of that cheap gas kills expensive parts (+ the labor to replace them).
konatown
2010 Genesis Coupe
Its exactly true, I use only 93 and from BP mostly.So car ran fine today, just like Goody said I had a lot of white smoke for the first moment.
goody90q45
konatown wrote:So car ran fine today, just like Goody said I had a lot of white smoke for the first moment.
Great news. Give us the details. Did you replace the injector/o-ring, pull the plugs?
qsiguy
Car: 1994 Infiniti Q45 Turbo
So what causes the "terrible noise" when you were attempting to crank the engine? I think I'm missing something.
konatown
2010 Genesis Coupe
Thats what I'm unsure of also. I'll have my car in the shop tomorrow looking for any further damage/problems.
I changed the injector out. Have a new one on order.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Might want to consider changing your oil and filter also if all that gas got into crankcase.
Mint Q45A
Car: 1994 Q45A
Goody94 stated the following: I've got a feeling the previous owner had the fuel rail out of my Q just before I bought it. My experience both times is the lower o-ring gives out and floods not only its cylinder but all 4 in the bank.
I am not sure I understand how one injector can flood the four cylinders. Is this really possible? How does the fuel get to the other three cylinders? Aren't the lower air runners completely independant?
Tks.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:I dont condsider injectors to wear out.
Depends if you know their gasoline diet, fuel filter replacement schedule, or can verify their performance on a bench.
Many owners is crapgas states do have to replace them periodically.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Mint Q45A wrote:1.) I am not sure I understand how one injector can flood the four cylinders.
2.) Is this really possible?
3.) How does the fuel get to the other three cylinders?
4.) Aren't the lower air runners completely independant?
1.) Only needs to flood one cylinder to hyrolock it, and bend a rod on crank. Engine dead.
2.) See 1.) above.
3.) Doesn't have to. See 2.) above.
4.) Yes, but that is not relevant to any particular cyliinder being flooded due to a leaky injector.
Mint Q45A
Car: 1994 Q45A
Maxnix,Tks for the feedback. I am aware of the risks of hydrolocking - even one cylinder is enough.... but I wasn't sure how just one injector could affect the other cylinders. I guess it doesn't.
Something I tried in order to remove the injector withouth fighting it: once you remove the screws and cap that holds it to the rail, simply add a couple of drops of light oil to the top of the injector (so that if sips to where the O ring); let is sit for a little. Then you can twist the injector a couple of times and it pops out, easily....
goody90q45
Mint Q45A wrote:Maxnix,Tks for the feedback. I am aware of the risks of hydrolocking - even one cylinder is enough.... but I wasn't sure how just one injector could affect the other cylinders. I guess it doesn't.
I'm not sure how it happens either but I do know that all 4 cylinders in the bank were filled with fuel, verified by removing the plugs, and fuel was pouring out the cat. Replacing the o-ring on one FI fixed the leak.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
goody94q45 wrote:I'm not sure how it happens either but I do know that all 4 cylinders in the bank were filled with fuel, verified by removing the plugs, and fuel was pouring out the cat. Replacing the o-ring on one FI fixed the leak.
Oh, in that case, I would assume it was pumping out of the flooded cylinder into the empty ones through the valves? Manifold sits up high enough the fuel couldn't cross over to the other bank?
yodawill2000
Car: 94 Infiniti J30
seems that would take a lot of fuel.A leaky injector quits leaking once the pressure is at zero right ?Weird.
Mint Q45A
Car: 1994 Q45A
Or more than one of the injectors was leaking....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Mint Q45A wrote:Or more than one of the injectors was leaking....
Not in Mike's case.
goody94q45 wrote: Replacing the o-ring on one FI fixed the leak.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I replaced my #8 injector with one that I bought from cccpman. No rough idle. After having it put in, I had to turn my radio off to make sure my car was still on while I was stopped at a light. I didn't feel a thing. I paid $6.25 for that injector and I wouldn't mind the repeat labor for that one or the #1 and 2 injectors. The others might be a pain.
