DGA »
https://forums.nicoclub.com/dga-u13015.html
Sun Feb 29, 2004 7:53 pm
If you want all the goodies, go to JEGS.COM. They cater to all the domestic race/stock parts stuff. They even sell full transmissions and for $1500, you should be able to get yourself a TH400 that can take well over 600 HP. My suggestion would be to take one from the junk yard for cheap and just have it built to take over what you hp goals are. That should run you about $1500 ever since every transmission shop is more than familiar with these units.One of the guys I worked with had a '69 Camaro that made about 600 hp to the wheels, and the cool thing was that his engine would rev past 12,000 rpm (That is right 12,000 rpm), and he had a TH350 bolted to that thing that was built by some shop in California that builds these things for 3000 hp dragsters for about $3000, and they even guaranteed his transmission for life. I know that this is 2 as much as you want to spend, but be sure in this though, if you have a TH built by a place make sure that they guarantee their work for life. Odds are that your engine will blow up before a TH would.All in all my hat goes off for you for your endevour. Good luck.
