nissanfanatic wrote:Look buddy, despite how good you think your tuning method is, that isn't how you set timing on an EFI system. Beyond your "listen for detonation" world, there is a load vs throttle position vs RPM world where you have to "SET" base timing correctly. Not just change timing wherever you think you should.
That link wasn't necessarily for you, as its clear that you don't need to do things like Nissan does...
And how much power do you make again?
Wow, did I word something incorrectly to insult you or excite your ego? I was simply stating that, no matter how you tune, you can't rule out audible knock. In even more plain English, if you're tuning, hear audible knock, then you MUST do something about it.
I didn't say I don't need to do things like Nissan does. In fact, as stated in my previous post, today I'll be re-timing the car, according to the helpful link you gave me. Didn't I thank you for the info?
And how much power do I make? What, are we 16 now? Sheesh.
Back to my question, and please, someone with much more control over their ego answer:
How, exactly, does the ECU use the distributor as a cam angle sensor?
This is not a question to cause an argument. This is a question to further educate myself, because I'm not opposed to learning something new, acknowledging that I'm less knowledgeable than others, etc. Not trying to re-invent the wheel here, just tryin' to figure out why it rolls the way it rolls.
