S13 SR w/ T2 GT3071R .86 AR (nothing fancy)
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Well, I picked up some plastic razor blades for my scraper today, so they're less likely to tear up my block, and I also picked up the head today.. He said he removed 4 thousandths... Is this a safe number to use the 1.1mm head gasket or do I need to go thicker?? He also said it looked as if something solid had gotten into my intake and bounced around in there... He had to resurface 2 of the valves. (1 intake and 1 exhaust) He mentioned possibly a pieced of a piston ring, but when Roman and I inspected the block, we didn't notice any damage on the 2 pistons at the top, and there's no damage to the other 2 cylinder walls, so the only other assumption is something that went through the intake... Either way, everything is going together this weekend. Hopefully my headgasket will seat well and everything will turn out perfect.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
.004 isn't too significant, but I think it's all going to be fine. A 1.2mm headgasket would make up the difference, do they make 'em that size?
PyR0NiAk
Well, I'm pretty sure the stock head gasket is 1.01 and people use the 1.1 to make up the difference for resurfacing and things of that nature.
PyR0NiAk
Head and exhaust manifold are installed.
I still need to make a block off plate for the IACV delete, and I can't seem to find the JWT lube for the cams. Anyone else know what type of lube I can find at autozone that'll work? I'll keep tearing my garage apart to find it, but it'd be nice if I could just go to autozone and pick something up.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
ask for assembly lube at any autoparts store.
PyR0NiAk
USMCgetsome wrote:ask for assembly lube at any autoparts store.
Thanks. I'll do that tomorrow. My ecu is scheduled to be here wednesday with the jwt tune on it, so hopefully I'll have everything bolted up along with the fuel pump hardwired so I can start her. I'm so excited, it's unreal.
PyR0NiAk
I stayed at a local resort all last week, and then participated in an autocross Sunday, so my S13, of course, got delayed. Here are a couple pics though. I did finally get the cams in along with the cylinder head sub bolts, and also got the sexy valve cover on.
The car in it's current state. I know, I know it needs lowered and some serious body work, but it's on it's way.
Close-up to show how great of work Zach did. The coil pack cover is just spray paint.
Bed Time
speedeast
It all looks great dude! Keep up the good sh*t!
zach-Ka
Car: 1990 240sx (SR)
Great progress. Despite the title, I think this is kind of fancy...
PyR0NiAk
zach-Ka wrote:Great progress. Despite the title, I think this is kind of fancy...
Thanks, Zach. The thread is mostly just for documentation so I can one day say, this car started like this, and ended up like this. Everything has been done with an image in mind, of exactly how I want it to look and perform. It's just a matter of me being able to pull it off. Being in the military gives me a steady enough income that I can do pretty much whatever I want, given I'm patient enough to save up for it. I'm just thankful my wife is so understanding about how much I enjoy building this car. It seriously sat for 3 years before I even started wrenching on it.
zach-Ka
I understand. That takes some dedication to have it sit there for so long. And it definitely helps haveing a understanding significant other.
PyR0NiAk
Alright. The car runs. It has an intermittent miss... It's either the cheap ebay fuel rail not sealing well, or a spark plug is gapped wrong... I didn't check gaps so either one is pretty likely. It's 1:30 in the morning here, and I'm sure my neighbors are VERY tired of hearing my elbow only exhaust fire up, so I'm done f*** with it for the night. I'll try and finish it most likely Monday, seeing as how tomorrow is my wife's birthday and then Sunday is Mother's day.
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
The MAF is wired correctly now
I believe his problem is:
fuel pump or FPR... or all together
by the way I don't see the words "I want to say special thanks to Roman AKA ROMEO_RUS for helping me with project since the second day of my work on it. You have been with me all the time helping me with everything! Without you this project wouldn't be finished. You put as much work into it as I did. You actual work and bringing all you personal necessary tools were very valuable and you knowledge is conclusive... ETC...ETC.." LOL
Congrats man!!! you made it now I want to see you red rust-bucket with torque-less SR on the road kicking asses of Mustangs and Corvettes.
PyR0NiAk
Rust bucket?? I've got 2 spots that need some attention... Both are cosmetic and are minor compared to what most S13s around here look like. Besides, there's a thank you to you on the first page.
Romeo_rus
Just kidding... We'll get it completely done by VERY SOON!!! Glad you got home safe...
PyR0NiAk
LOL, I was good until I got back to base. The 20mph speed limit through housing like to freaking killed me.. I came home and immediately looked to see if I could possibly warp the stock fuel rail back to how it needs to be... There's no way. :(
PyR0NiAk
Correction: I got the fuel rail straight, it wasn't as bad as it looked... I placed it on a counter and slowly pressed on it... It straighted right out, which is exactly what 240sxmotoring.com says to do about it. Now I just need to install it and start the car again...
PyR0NiAk
ISSUE SOLVED... loose fuel injector wire on cylinder number 3
S13srdave
Car: '89 s13 w/ redtop sr swap, gt2871r
J240sx wrote:Nice build, let me know how you like the isis parts. All the comments I hear about them is from people who never used their parts.
Yeah, I have the same ISIS intake mani and I didnt have any issues with it except that the brackets for my JGY fuel rail didn't like up right. I had to make my own brackets for the fuel rail and the throttle cable, but it performs nice. A little less low end torque, but you can really feel a difference up top end. Nice build.
PyR0NiAk
S13srdave wrote:A little less low end torque, but you can really feel a difference up top end. Nice build.
If you have looked at my parts, you probably realized the car is designed to be a top end monster... S4 cams and a 30 series turbo say 4000+ only... Hell the S4 cams don't really make any power until 5500 rpms
Thank you, by the way.
PyR0NiAk
So I have all of these pretty parts, but my wiring harness is looking a little rough... Definitely makes my bay look sloppy. I decided to do what I've been talking to OM3GA about since before they were producing these. I ordered the S13 - S13 upper harness from wiring specialties... Pics will be posted as soon as I get it..
zach-Ka
That harness looks real good. I cant wait to see it installed..
PyR0NiAk
O.K. Here goes. The new harness came in and I installed it. I'm finally out of limp mode. Other harness had me in limp mode because I really didn't feel like tracing the wires to figure out which was which to wire up my Z32 MAF.. (The MAF extension was all done with one color.) The car is now at National Speed Inc. in Wilmington, NC where they are diagnosing my sputtering issue. (I'm pretty sure it's timing related but I'm just so tired of taking the damn valve cover off as well as trying to diagnose everything with minimal tools.) They'll also be throwing it on their dyno when everything is done, so I should have some numbers to post up and actually be able to drive it home on leave.
Here's what the motor currently has done to it.
Brian Crower Valve Springs and Retainers
Jim Wolf Technology S4 Cams
Deatschwerks 810cc Injectors
No-Name Side Feed Fuel Rail
Walbro 255lph Fuel Pump (Hardwired with a Deatschwerks hardwiring kit)
ISIS Polished Intake Manifold
RB25 Motor Mounts
Tomei Expreme Exhaust Manifold
Cosworth 1.1mm 3 layer metal head gasket
Garret GT3071R .86AR with T2 Flange
Jim Wolf Technology ECU Tune
Wiring Specialties S13 SR -> S13 Wiring Harness (PURE SEX)
Mishimoto 60° celcius Thermostat
Koyo Radiator
HKS SSQV (Atmospheric)
Greddy FMIC
MR Turbo Elbow and Downpipe
ISIS Turbo Lines
Z32 MAF
MR FPR
speedeast
It's B-E-A-utiful!
PyR0NiAk
Bruce All Mighty quote. Nice...
zach-Ka
Looks really good man.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Glad to see everything coming together! Now its gotta be my turn to update my build thread soon. HAHA
DeatschWerks
Hey, hey...alright man. Good to see you getting it squared away. It'll be good to drive a solid car again, eh?
PyR0NiAk
It'll be good to drive a car that's not slow. That's for sure.. :)
Romeo_rus
СHRIS!!! I'm glad to see your car finished!!! CONGRATS!!!!
I work at an autosevice in Raleigh, so I'm waiting for you to come and get some work done to it...
you GET A HUGE DISCOUNT ON LABOR AND BODY WORK!!!JUST GIVE ME A CALL
