the factory needle DEFINITELY sucks. but as long as the needle never goes above the middle, you're fine.Nismo_Freak wrote:The only thing NO one should rely on is the factory needle... it's horribly inaccurate and YES, you can be overheating with the needle still in the middle.
i had a nismo thermostat on my last 240, never had problems, but thats not the issue... the issue is that it may be running cooler than what it was intended to run at.
another cool thing to use is the techtom cmx-100 for determining water temp. its a little pricey but worth it because it has some extra features and just plugs into the consult connector. i think the project silvia used the same thing... im definitely getting it for the ease of installation and i find the injector duty % useful when upping the boost. ( http://www.specialtyz.com/techtom.htm )
