Projector Pop up headlights done before?
sorrowfulkiller
Just wondering if projector housing pop up headlights have been done before on an s13... any pictures if it has been done?
sorrowfulkiller
i should actually have said a pop up headlight that is a projector housing that still pops up, not one that keeps the headlight down and shines the projector through the bottom due to the body kit's shape
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i still dont know what you mean but i have retrofitted projectors in my h4 housings
sorrowfulkiller
chaosli wrote:i still dont know what you mean but i have retrofitted projectors in my h4 housings
got pics?
Okay what I mean is you know how the stock halogen pop ups are? I'm asking if anyone has replaced the glass lens housings with a projector housing. That way when the lights are on they are up like normal, but have projectors, and when they are off then the headlights are down like stock.
chaosli
99 mazda miata
93 bmw 325i RIP
i have a projector in that glass housingdidnt do too great of a job i could do better but i am lazypics
cut off line
if you have a projector thats already sealed you could use that with a bracket or something
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
i've done it but i didnt like the look, to ricey for me. i just got new oem lights
Rellik27
Car: 240sx
sorrowfulkiller
Rellik27 wrote:zerothread/254025
Thanks for the retrofit diy link
When I buy an s13, I'll probably do this... but I'm planning on having it look a little better... I'll only use the original glass housing as a frame and use plexiglass to protect the lens
how large are these ebay h4 projectors compared to say an fx35 projector?
Modified by sorrowfulkiller at 11:48 AM 6/1/2009
edgartheace
Car: 1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
I used the FX35 projectors on my retrofit since they have the HI/LO beams on the same projector. here check it out.
zerothread?id=264379
sorrowfulkiller
edgartheace wrote:I used the FX35 projectors on my retrofit since they have the HI/LO beams on the same projector. here check it out.
How much room behind the projector do you have? Would you be able to mount them any further back at all?
Still looks like something that could be improved on though, you should always have something to protect the lens of the projector.
Lenses are not cheap O_o
edgartheace
This was just a rough mock up. I haven't had the time to finish the housings the way I wanted. But thats as far in as you can put them. any further in and your lights will not retract all the way down because the plugs will hit the chassis.
sorrowfulkiller
edgartheace wrote:This was just a rough mock up. I haven't had the time to finish the housings the way I wanted. But thats as far in as you can put them. any further in and your lights will not retract all the way down because the plugs will hit the chassis.
Ah, okay.
Not too worried I'll be cutting the hell outta the front chassis when I get the car. Planning a v-mount that still keeps the A/C. It will be interesting to say the least.
