DammitBobby »
https://forums.nicoclub.com/dammitbobby-u6954.html
Sat Aug 13, 2005 6:21 am
Problems with JWT ECU , 72lbs , Z32 MAF and Open BOV.
1 big problem is idle.
2 problem with open BOV after you let off it stumbles for about 15 or 20 seconds. Gets way to rich with open BOV after boost.
The car is pretty much non drivable unless you like stalling out at every stop light. Which brings me to the conclusion if you plan on going this route you are going to have to install SAFCII and Wideband.
COSTS:USED JWT ECU 380.00USED Z32 MAF 150.00Deatschwerks 72lbs 275.00Apexi Cone filter Z32 77.00
Now stuff I need to actually make all this work.
NEW but not used SAFCII 210.00Zeitronix wideband 400.00 Total 1492.00
300 more then what I wanted to spend.
