Darius »
https://forums.nicoclub.com/darius-u5470.html
Fri Nov 03, 2006 4:46 am
There is no way in hell anyone in their right mind would consider attempting to start a motor that looks like that without tearing it completely down and inspecting it. The thing looked like it got sprayed with a shotgun.
Evo_bill, I consider you in the same boat as I was when I first started researching this swap. I read for a year and a half on here before I pulled the trigger on a clip. You need to sit down with a good read (i.e. the FSM) and buy a basic engine building book. You need to do a complete rebuild on this motor before you put it in or do it after it blows up because more likely than not, it will. I recommend doing it while you have it out of the car still. Buy some good micrometers (Starrett), mic the crank, measure the mains, measure the journals, measure the girdle, buy new bearings accordingly (King from Compulsive HP), new main bolts, etc. to get that thing to a point where you feel comfortable that it will last the length of time you want it to under the abuse you are planning on giving it. We're all here to help you out, but do your research and THEN ask questions.
