Roger,riu wrote:i'm sorry but that looks like a terrible place to mount the turbo, the first driveway you see and you're going to smash that thing. i dont' trust mounting anything lower than the lower radiator support.
you think you could possibly mount it right under or next to your intake? that way it sits a good 6+ inches higher than the smic mounting points. and then take out the extraneous snorkel intake tubes for the stock airbox and run your piping through their?
your project is in too good of shape to just risk putting the turbo there
Hi Shane,qsiguy wrote:I agree on the injectors. It's too much work to take off that plenum once you get this beauty together. Shouldn't be difficult at all to just take a stock bin and change the K value and latency. I haven't messed with the latency but I have the K value and it's simple. I'll have to look around to find it but I seem to remember coming across a simple program to help you calculate the desired K value.
Cool - thanks Shane. My coated/plated parts weren't completed as expected on Friday, so I'm looking at getting everything back next week. I looked around and think on the MAF I'll be buying the 3.5" Diameter Pro-Tube (http://www.promracing.com/products.htm) from pro-M racing. It's specifically a blow-through design MAF and my understanding is that it can handle practically anything we can throw at it.qsiguy wrote:Sounds like a plan. I'm looking forward to seeing how well Nistune works for you. The stock K value is 198 with 370 injectors. Going to 555's I believe you would change it to 132. Not sure of the other values yet.
Not sure how your dual MAF setup will need to be setup. For mine I had to expand the TP scales because stock only went up to 72 and I'm hitting TP's up to around 100. I expanded mine up to 128. With the dual maf's your's may not go that high since it's only reading half the air flow. Stock may be ok. You should know more once you do a map trace and see where the TP is.
npez wrote:This approach will probably cost as much as getting everything professionaly done, but at the end of the day I will end up with more tools I can use in the future, and the satisfaction of having done the work myself!
Nick.
Thanks Tyler & Steve. I picked up the Millermatic 140 with autoset. I think it'll serve me pretty well for the fabrication I will need to do and seemed like the simplest to setup and get going. On the tank they offered to do it either way exchange or discount a 2nd tank. I'm leaning towards just buying another 122CF one and calling it a day With my luck in the middle of doing stainless I would then need to do something with mild steel and not have the gas. They told me to steer away from flux core wire unless I want to be cleaning up after the fact (which I don't) or welding outside (which I'm not) so I'm sticking with gas shielding.tmorgan4 wrote:Good decision on picking up a welder. Worst case you can get everything tacked up and assembled the way you want it and bring it somewhere to have them finished if it comes down to it. I forgot that you need to have another tank to weld stainless with a MIG! Are you planning on picking up another bottle or just exchanging the one you've got? Would be nice to have one of each on hand.
Which welder did you get? I think you'll pick it up quickly.
Hi Carl,Carl H wrote:a welder along with a sawzall is one of the most important purchases you'll ever make...i finally figured out mine and laid down some AWESOME beads.too bad i didnt figure it out before, oh well.As far as tanks go if you plan on doing fabwork alot then having a tank of ar/co2 is a must (atleast 40lb tank), a dedicated tank of ar for al and depending on how much ss you do you can squeek by with the ar tank...but if you're doing alot then definately look into a dedicated tank for that.word of advice tho, dont buy welding supplies from home depot or northern tools...go to a dedicated supply shop for industral purposes prices are ALOT less and they're pros at the game.
I think it was the evolution. I think the price was four hundred and change for the chop saw. I did some research online and man I didn't know blades cost $120 each. I'll need the one that comes with it (mild steel) then the $120 one for stainless. Carl, from what I've read the blades last 800 cuts of 1/8" wall tubing 3-1/2" tube. Not sure how long it lasts cutting through solid material, but I'm mostly interested in tubing.tmorgan4 wrote:Do you remember what the saw was? I've read a few mixed things on the Evolution saws with the carbide blades.
Just in case you haven't already seen it, Burns Stainless has some good tech articles on their website talking about the different grades of stainless.
http://www.burnsstainless.com/....html
The K value doesn't really reflect any sort of injector size or anything. 198 K being stock lowering it to 132 will be for the 555's. The K value is just a number the ECU uses in it's calculations to determine the pulsewidth of the injectors. Lower K value it will hold the injectors on for a shorter time. Since the larger injectors flow more fuel they need to be on for a shorter time to provide the right amount of fuel. If you don't change the K value it will be rich across the board (except maybe when you are in boost) and may not idle.npez wrote:On the 132 K value - is that based on 555cc flow rate? I ask because Nismo calls them 555s but they actually flow 615cc. I downloaded everything from Nistune, so I'll spend some time installing the software and then start the work on the socketing.
Shane,qsiguy wrote:Correct. The tricky think is that Nick is going to be using a dual MAF setup with one dummy. I believe the load (TP) scales are going to be the main thing he might need to tweak for that. Sounds like the Nistune software will do some of these adjustments automatically. To get the car running I'd say setting the K value lower should get him started and idling.
Once you can get some map trace results you'll know where your TP is hitting and then you can tune the fuel and timing maps from there.
Shane,qsiguy wrote:Thank you for the update. That changes everything. Looks like a really nice unit. From the info on the site I couldn't tell if it is user adjustable or if they have to do it for you upfront. Did you already buy it or speak with them? I'd like to know the details of how they get you setup. I'd also like to see a wiring diagram for it. Is it the same voltage and output type as the OEM MAF or are there other mods you'll need to do?
Tyler,tmorgan4 wrote:Just got done watching the news and realized there's a few of you guys right down there. Looks like a lot of damage...hope everyone is doing fine!
Thanks man! On a positive note UPS/Fedex is delivering so all my stainless tube and mandrel bends arrived today along with my bench grinder and dry-cut hitachi chop saw. Now if I only had power to use any of thisMettler wrote:Holy crap dude! Good to hear you're ok.
real glad to hear you made it alright...our house was pretty much unscathed however my back fence is trashed on all sides, half of my swimming pool is gone, liner and shell and all, and worst part is the roof over my back patio ended up on top of my car...after i cleared the debris i was fortunate to find only scratches and no dings or dents...oh and get this...since we were evacuated from our rigs offshore me and a few of my buddies with chain saws have been going around cutting up trees and what not...weve underbid every tree company weve encountered and between 3 of us have cleare $2000 from saturday to monday....they have yet to tell us when we can go back offshore so now were rebuilding fences...sorry to hear you dont have power yet...my wife was bitching about not having it because the neighbors across the street got their power restored sunday morning and we didnt get it back until monday afternoon...i explained to her that theres still 1.4 million people in houston who dont have power so we are very fortunate...i know im all the way across town but if theres anything i can do to help yall out please let me know...i know gas is scarce but if need be i can find some and make my way up there...best of luck to yall-Knpez wrote:Tyler,
We got nailed pretty hard. The area I'm in is 70-80 miles from the coast and IKE came over as a Category 1 storm. Fortunately I fared out ok, my house is pretty new so the construction can handle a cat1/cat2 storm.
The only bummer is that the area I live in has a lot of trees which many snapped or got uprooted and toppled over. I actually saw some pines that are 18-24 inches in diameter that the trunk twisted and snapped (that's pretty major torque). So all the trees fell on power lines and we haven't had power since the storm. I'm using an inverter and my aircard to look at the internet but that's about it. Not sure how Jerry and the others have fared.
I'm ordering a 20-25KW standby generator this week that'll be able to power the whole house, as I refuse to be in this situation again. At least the weather has been cool by Houston standards - 60's for a low and low 80's for a high.
Anyway, I hope to post some progress after we get power back and get back into the groove of things......
Thanks,Nick.
