craigztoyz wrote:What about drilling out the second bolt hole through the mount I made. I'd be a P.I.T.A., but doable, could you get to the nut, would be the problem.
Neighbor with a C6, just drove by, 20 ft behind, a friend in a new viper, guess they are going to play. O I cant wait to get this one's bugs worked out. Ordered a Griffen, 28 x 19, with fans, be here in a week. That should take car of the cooling.Glad to hear its almost up and driving. Going n/a at all, or just boost now.
I don't think I would be able to get to the nut without some heavy cutting. That's the reason I was looking at something like Bart's setup with the horizontal bolt.
I'm planning on starting it up N/A and driving it to make sure everything is working as it should. Before that happens though, I still need to design a custom front swaybar and mounting of it so it's coming in from the back to the front. I've posted a question on the 300ZX forum to find out what the factory sway bar rate is so I can match it. That's the last thing I will do, but I still need to get the manifolds/plumbing for the turbos fabbed, then send everything out to High Performance Coatings and get it and the turbo housings coated in HiperCoat Extreme. After all that's done (I think it'll all take about a month) I will then do the Ostrich2 install with Nistune and make sure everything is running properly with the modified ECM/Factory Tune. Only when all that is done will I start Phase 2A.
Phase 2A will include the install of all the parts I've already bought, are currently buying, or already have; the 555cc injectors, oil cooler and greddy sandwich adapter, scavenging pump, factory intercoolers/new plumbing, water injection, turbos, wastegates, BOV, etc. to get into boost for as much as the engine will tolerate (I hope 8-9 psig maybe 10) and of course tuning.
Depending on how the car "feels" after Phase 2A, will dictate how long I stay in 2A. If the car gets squirley and uncontrollable at that level of power, then 2B will need to address this before spending big $s on custom CP pistons, custom Pauter rods, etc. and turning the boost up to approximately 18psig.
We'll see, but I'm hoping in August to have all the parts back so I can run the car N/A. If all goes well, I should be under boost sometime by the end of September if I boogie.....
Thanks,Nick.
