So, tonight I spent a lot of time figuring out the next step for the Lexan windows. The plan is to run all Lexan all around except for the front windshield to be able to squeek by on legality.
Tonight I ended up mocking and fabricating a set of quarter glass windows and got some ideas for what I will do for the door glass and rear glass. Here you go.
This is what I was starting with. I originally had the quarter glass windows but still wanted to use the moldings to get a stock look. I simply hate the way a piece of lexan is just drilled and riveted into the body. Doesn't look clean at all. So, I opted to strip away the quarter glass parts I didn't need.
Anyways, this is our starting point. Obviously, everything is stripped off the quarter. Glues, adhesives, paints.....the whole enchilada...no hidden sins...to get us to here to this point, a clean mounting surface.
From here I took the original glass and removed it from the body using a simple glass removal kit from Harbor Freight (around $15 for the kit) some time back. I then took the glass and removed all the moldings, permanently attached tabs and adhesives. All I wanted was the stock glass to start from the ground up for a mold. Even the tint needed to go as I need to make a template also of the glass black out area, so that I can make my lexan piece look exactly like this one.
This is what I want. Just the glass....finally.
Here is a basic mock up of what I want, using the original glass.
Now that I have my glass out. I make a simple template.
From here I took a piece of lexan that was the exact same width as the glass and cut out my piece using the above template. I used the exact same glass so that I could use the original quarter glass clips. These are important as they will allow me to simply clip in the rubber door moldings ( the same ones that everyone replaces all the time) that go over the glass. But the hardest part was forming, with a heat gun and by hand, the lexan to the same form as the oem glass. Here is the piece formed, this took about an hour for each quarter to mimic.
From here I layed out my holes according to how the lexan will stress the most and of course taking the look into account as well. Gotta look cool too.
After that, I simply added my drill points to the quarter via marker. Punched the sheet metal and drilled the holes to accept rivets later on.
And here is mock up. Still have to paint the jambs with the car color later, buff and paint the quarter glass, install my lexan NACA ducts into them, lay down bonding adhesive and lastly install them. It will be a while till you see these in. But at least all the hard work is done. And.. YES I know it's rough but I plan on clean up the edges before install and also remember that moldings WILL be going back onto this lexan.
So with that done, I moved onto the door glass. The problem I am running into with the door glass is mounting. I no longer run an interior track which is the whole support for our door, so I have to come up with either a bracket or reinvent the track to allow the glass to stay stationary. I may just make a lip that will run the length of the glass on the high part to give it some rigidity. But who knows, still working it out in my head.
I also have a plan run a sliding door on the window as well, but have to figure out how to do that too. This glass will be a pain. But anyway, this is all I really got to on the doors.
Took the original glass and simply removed everything to get a nice template.
Here is the cardboard template. Not the stock moldings are staying place to still allow water to drain in the same stock way the car did originally. For the record, that cardboard is packaging from a Toyota bumper that I snagged from the office. Boooooo.......hissssssssssssssss..............
Lastly, I worked on my layout for the rear glass on the Powertrix Carbon Fiber rear hatch. This is a bit tricky but nothing near as bad as the door glass will be. I will have to use a thick lexan so that I won't have to use a bracing in the middle of the glass, that will simply impeed my vision. So forming it, although minimal in angle, will still prove to be a pain. But hey, gotta make it look cool.
Here is the OEM glass in place. From here I will build a layout of my holes in the lexan that is coming in shortly.
From here it's a lot of measuring and game planning. *sigh*.....this took a while to get all those holes layed out perfectly.
