Cyberkreig wrote:ALL ov those things should be checked during an SR swap. Most will be replaced.
And that = money, the same amount of money that would be used to replace the same things on the KA.
Cyberkreig wrote:SR does not need to replace any of those things for 250rwhp.
Yes but you have to buy those things in the first place(the infamous SR front clip) the same money would be going towards buying pistons, Engine managment , etc.
So all in all its about the same amount of money. People readily recommend in the SR section to have at least 5500 ready to spend. That same money could have you a turbo, manifold, rebuild, radiator, intercooler, hacked maf, injectors, etc.
As someone said earlier, the money doesn't matter, it could be more one way, or more the other way depending on what happends during your install and running of the engine. The difference is where the power is.
